How to tighten the strut top nut?
Old Apr 1, 2010 | 11:06 AM
Aeromax's Avatar
Aeromax
Just now on my lunch break, I took the car home and gave each strut top a quick tug with a breaker bar and a 21mm socket. They were both tight. This was done with the car on the ground. Does this mean they are ok, or should I raise the car up and take the struts out?
Old Apr 1, 2010 | 12:50 PM
rsvp9146's Avatar
rsvp9146
Why do you feel the need to tighten them?
Old Apr 1, 2010 | 01:18 PM
Aeromax's Avatar
Aeromax
If you could hear what my suspension sounds like, you'd understand.
I've heard a loose top nut is a common issue when getting clunking over jarring bumps, and I have done work to the shocks and subframe.
Old Apr 1, 2010 | 06:30 PM
earlrabbit's Avatar
earlrabbit
Probably all you did is spin the strut shaft as you tried to tighten the nut. You really need a special socket with the side cut out (if you're handy you can make one) that allows you to put an allen wrench on the shaft to keep it from spinning as you tighten the nut.
Old Apr 1, 2010 | 06:46 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Here's a good deal on tool you'll need.
21mm Strut Tool and spreader
Rich
Old Apr 1, 2010 | 06:52 PM
MINICHEF's Avatar
MINICHEF
more important would be thr 3 nuts that hold the strut to the tower. Torque these to 30-35 lb/ft with a 13mm socket. They tend to loosen due to mushrooming of the towers.
Old Apr 2, 2010 | 05:00 AM
THE ITCH's Avatar
THE ITCH
MINICHEF
Sorry this is bad information. The torque on the three camber plate bolts is 25 ft/lbs. Going any higher than that and you risk breakage!
Steve
Old Apr 2, 2010 | 07:18 AM
Aeromax's Avatar
Aeromax
So I took the struts out yesterday, reinstalled them, checked the fittings, and everything seems tight. I still have a terrible clunking noise. I'm not going to look into some outer ball joints, and just start going down the list of things to replace!
Old Nov 20, 2013 | 10:00 PM
rockjohny's Avatar
rockjohny
Would that be a common mistake in reinstalling struts (not tightening the main nut)? I have the bad rubbing issue in the struts after having new bearings installed...did they overlook the proper way to tighten them?
Old Nov 21, 2013 | 05:05 AM
v10climber's Avatar
v10climber
If you had a shop do the work then they probably just hit the strut nut with an impact (common practice) and it should be plenty tight. Is the rubbing in the front or rear? What do you mean by "bearings"?
Old Nov 24, 2013 | 07:19 AM
JRhea's Avatar
JRhea
Last Winter I replaced my struts, strut bearings, inner ball joints, installed MINI Madness reinforcement plates, (to fix minor mushrooming) and any other associated strut bushings and stops. Several months ago the struts started clunking at slow speeds such as going over the transition bump into my driveway. Thinking it was lose strut nuts, I hit them with the impact wrench and it seemed to help. But now its getting worse.
I might have found the problem although I haven't looked into this yet. When I replaced the struts, I went with a mid-priced strut bearing; and that might be the issue. I was discussing this with a mechanic and he said he had a bad experience where the after market bearings he installed failed almost immediately. With everything else seemingly tight, these aftermarket bearing might be the issue, and could be failing.
Side note: In one of the earlier post's someone was asking how to tighten the strut nut while holding the allen screw. With the strut assembly out of the car I used a spark plug socket that had a wrench fitting on the end. This way you can tighten it with a box wrench while accessing the allen screw through the middle. This method might work with the strut assembly in the car as well.
Old Nov 25, 2013 | 12:50 PM
rockjohny's Avatar
rockjohny
I used Moog which might be the problem after reading this:
http://www.bobistheoilguy.com/forums...Number=2643612
But they rub/squeak only when it's below 70. Is that a sound you'd hear when they're failing? The ones i replaced were tearing quite bad but didn't make any sounds.
So either the struts weren't tightened right and somehow that is causing the bellows to bind or the tower plates added are touching the rubber bearings - after that i have no idea.
My mechanic hit everything he could with lithium grease but if that helped it didn't help long.
woodstudio
Mar 15, 2020 08:28 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
