TPS, technical questions
Old Mar 26, 2010 | 02:34 PM
tvrgeek's Avatar
tvrgeek
OK, I now have some 17 x 7 inch OEM wheels to put some decent 215's on my 2009. Conventional of course as I am in the camp that believes tires are half the suspension, and the car should not let tires go airborne over bumps in corners. At least not street cars. Race cars, or my old Morgan, OK; not a 2009 production car.
The run flats TPS system is set for 33 Lbs. With conventional tires, this is possibly higher than I would want in the rear. I would like to be able to have the TPS set where I want it based on the tire, vehicle loading, suspension settings, and my handling preferences. In other words, correctly.
So, is the sensor proprietary to the MINI only?
Is it a binary sensor and the ECU just says Yup, it's low, or is it an analog sensor and the ECU decides the set point?
Can I buy sensors with different set points? Say from other BMW's or some generic house. I plan on keeping my old wheels and tires in tact, ( one as a spare tire in the car), so I don't want to dismount them to get the sensors.
Old Mar 26, 2010 | 05:03 PM
Lil Q's Avatar
Lil Q
Inflate the tires where you want (according to specs) and reset the tpms when you are ready. Should save your pressure(s) once reset is complete.
Old Mar 27, 2010 | 04:02 AM
tvrgeek's Avatar
tvrgeek
That would be great. HOW does one "reset and save". I know VW has a feature to save, but I can find nothing in the MINI documentation other than the fixed 33 Lbs.
Old Mar 27, 2010 | 07:02 AM
ran-o-matic's Avatar
ran-o-matic
Follow the instructions in the manual. You basically press the left stalk end button to get to all of your settings. One of them is the TPMS reset. There is no fixed 33lb setting - not sure where you found that.
Old Mar 27, 2010 | 11:47 AM
tvrgeek's Avatar
tvrgeek
Just re-read the book. My info was from the dealer. Clueless I guess.
Now I have to figure out if I need to file a flat boss on the s-lites I bought to mount sensors, or if they will mount OK. Don't know until I bust a tire off them.
Old Mar 27, 2010 | 01:13 PM
e30r56's Avatar
e30r56
tvrgeek, you are in bowie, right? bring one of those s-lites down to my shop and I'll test fit a sensor in one of them.
I'm with Admiral Tire on 301 a mile south of walmart in bowie.
Jeff
Old Mar 27, 2010 | 04:47 PM
tvrgeek's Avatar
tvrgeek
Jeff
Supper. I grab one when I get home Monday and roll on down.
We can talk tires. Thinking 960's but am open to suggestions.
donniedarko
Oct 21, 2015 01:15 PM
Panik
Sep 9, 2015 08:36 AM
Sep 3, 2015 02:06 PM
