Navigation & Audio Before I pull up carpet @ remove seats....
Old Mar 19, 2010 | 06:12 PM
jso123's Avatar
jso123
I'm getting ready to install an Alpine PDX amp under the passenger seat and run all the wires to a sub in the boot.
Never dealt with this before and don't want to cause any permanent damage. If someone knows a link about pulling out moldings and carpet, please point.
I know that I need to disconnect the battery first, and found a link about removing the back seats.... which seems manageable. However, those clips that hold all the plastic together scare me. It seems like I am using enough pressure to do damage before they pop off. Thanks
Old Mar 19, 2010 | 06:38 PM
schatzy62's Avatar
schatzy62
Pulling them off is a tough and you think you are breaking something and you may break some. I would recommend that you get some or order some before putting the panels back on.
Other than that there are a few threads that go into removal of the seats and rear panels on the R56 and the R55. just not sure where they are at this time.
Old Mar 27, 2010 | 03:07 PM
Robin Casady's Avatar
Robin Casady
Be sure you disconnect the battery before removing the seats. There is a connector under that seats that connects the airbags. If you disconnect it with the battery connected, it will cause an airbag error in the computer that only the dealer can clear.
Motown
Apr 20, 2018 09:31 AM
flredmini
Oct 1, 2015 05:03 AM
Mini'mon
Aug 26, 2015 01:02 PM
greekzilla
Aug 23, 2015 03:44 PM
