Suspension Criticise my suspension plans, PLEASE!
Old Mar 18, 2010 | 10:36 AM
ghurm001's Avatar
ghurm001
SO.. I've got almost $700 worth of parts in my cart over on Mossmini.com right now. I'm a little apprehensive of what I've chosen. Please tell me what you think of this:
I'm looking at putting the Sachs brand struts and shock absorbers on all 4 corners.. they're a stock replacement. that's the easy part. they're not bilsteins or anything, but they're better than the originals i'm riding on @ 114k+ miles..
my uncertainty is on the Apex lowering springs. they drop it 30cm (~1.2 inches). and I recently put some tires on, they're a little bigger and wider than stock (205/55r16). i believe they're about 1.5 inches larger diameter.
All in all, I figure that I'm only changing my stock ride height by -1 inch or less..
my concerns are that I'll bottom out the Sachs struts with the lowered springs, or that I won't have clearance behind my fender flare. Most other cars, I know, can have that edge rolled, but the Mini can't since it's a plastic trim piece.
Should I just skip the lowered springs??
Old Mar 18, 2010 | 11:09 AM
nickbmw's Avatar
nickbmw
In my opinion yes skip the springs and add in your order a 19mm rear anti roll bar or front camber plates, these will transform your car.
Also, the tire size you chose is not correct, 195/55/16 is factory on 16s, but the best for the R50s is 205-50-16.
Old Mar 18, 2010 | 11:23 AM
ghurm001's Avatar
ghurm001
thanks nick.
I realized this was more appropriate in the suspension mod forum and restarted the thread there.
https://www.northamericanmotoring.co...ns-please.html
Filmy
15
Jun 6, 2023 06:27 AM
ej
Nov 17, 2015 09:21 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Suspension Products
Sep 10, 2015 11:46 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
