Leak-prone areas?
Old Mar 16, 2010 | 12:05 PM
Aeromax's Avatar
Aeromax
Leak-prone areas?
So for a long time now, my car has had mysterious wet carpeting during periods of rain. A couple of times in the trunk, and now lately the driver's side carpet has been wet. Not super wet, but damp. My car also gets an awful mold smell during rainy periods. I don't have a sunroof, and my headliner isn't wet or stained. Are there any roof-drain channels in non-sunroof cars? What else can I look for? My door seals aren't torn or anything, but I haven't pulled up the carpet yet to inspect closer.
Old Mar 17, 2010 | 06:53 AM
JumpingJackFlash's Avatar
JumpingJackFlash
The windshield seal may be gone. This is definitely a possibility if you have had it replaced. Give your door and boot seals a good look with a fine-tooth comb. Water has a tendency to find the tiniest spots and make its way through. The only other thing that comes to mind is the two vented areas below the bottom of the windshield. Check the back area of the two front floorboard areas (i.e. behind pedals).
Old Mar 17, 2010 | 09:18 AM
Aeromax's Avatar
Aeromax
I have indeed had my windshield replaced. I will investigate that.
Old Mar 17, 2010 | 10:44 AM
ZippyNH's Avatar
ZippyNH
Take a look at the 3rd brake light for the trunk leak...also there have been a few leaks around the regular brake lights in the rear, so I'd look at it from the inside to look for drip marks too!!
Old Mar 17, 2010 | 12:49 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Even though you don't have a sunroof you still have the drain tubes. Just went thru this in my GP. I got some pine needles down the drain hole and plugged em solid!
Old Mar 17, 2010 | 01:10 PM
JumpingJackFlash
Interesting to know the drain tubes are still there! My only question then is... how did they get clogged?
Old Mar 17, 2010 | 01:50 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Another potential leak point on the driver's side is the firewall grommet behind the brake booster. If this has been used to route any aftermarket wiring (in my case lights, gauges, laser jammer, water/meth controller) into the passenger compartment, it can leak. Learned this during a downpour once with water running onto my left foot... resealed with silicone and no more problems.
Old Mar 17, 2010 | 02:19 PM
ALTA_Jarid's Avatar
ALTA_Jarid
There is a very small hole in the drip rail moulding..... a few pine needles and pluggo!!
Old Mar 17, 2010 | 08:13 PM
JumpingJackFlash
Jarid, that's a trip. Would have never though they were there. But it does make sense. Both my old '02 MCS and my current '06 MCS have sunroofs, so I would not have though about it. Hmm... maybe I do have those holes along the drip rail molding, too.
Old Mar 18, 2010 | 06:40 AM
Aeromax's Avatar
Aeromax
Originally Posted by BlimeyCabrio
Another potential leak point on the driver's side is the firewall grommet behind the brake booster. If this has been use to route any aftermarket wiring into the passenger compartment, it can leak. Learned this during a downpour once with water running onto my left foot... resealed with silicone and no more problems.
That's also very possible, I have driving lamp wiring going through there somewhere.
MC36
Jan 1, 2019 06:53 AM
keen
Nov 14, 2015 02:08 PM
ronn
Sep 9, 2015 07:12 PM
