Crank sensor o ring
Old Mar 16, 2010 | 11:37 AM
MINIsurf's Avatar
MINIsurf
Crank sensor o ring
Well after the month long clutch job from hell, and replacing the oil pan gasket and the main seal, i still have an oil leak, after some thread searching it seems like its the crank sensor o-ring. Now i know you have to take the front of the car of (to do most things on the mini..lol) but how difficult is it to remove and re-seal the o-ring? Does the radiator, compressor, etc have to come off?
Old Mar 22, 2010 | 05:05 AM
orvillespooner's Avatar
orvillespooner
Simple-just remove the radiator
Old Mar 22, 2010 | 06:03 AM
healey67's Avatar
healey67
no way!!! first if you have small hands you can get that sensor out without taking anything off. (but not everyone has little hands). If you take off the bumper and put the radiator support in the service mode you should be able to get that crank sensor out no problem.
Old Mar 29, 2010 | 06:48 AM
mantysman's Avatar
mantysman
I have an oil leaking running down the front of the engine, being blown back along the oilpan towards the drain plug. I thought it was the missing O ring on the oil dipstick, but after replacing that, the leak still exists. Could it be the O ring at the base of the dipstcik tube or is it crank sensor O ring? Before I tear apart the car I'd want to have both O rings in hand..thanks in advance for any help!
Old Mar 29, 2010 | 01:11 PM
03BRG's Avatar
03BRG
If you can't find the cause of the leak go buy the dye to put in the oil. I think NAPA sells it or go to a trusted repair shop. just found this kit http://www.autobarn.net/leakdeteq1.html
BernieCoop
Sep 10, 2021 03:15 AM
renchjeep
Sep 6, 2015 01:54 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Sep 4, 2015 09:10 AM
M7Speed
Sep 3, 2015 07:48 AM
