Drivetrain Copper Head gasket
Old Mar 9, 2010 | 02:33 PM
bebop86's Avatar
bebop86
Copper Head gasket
One of my mechanics mentioned that I should change the head gasket to a copper one which would create more compression and give more power- Does this make sense and has anyone done or recommend doing this ??
Old Mar 9, 2010 | 03:04 PM
k-huevo's Avatar
k-huevo
Thinner gasket (less than .65mm) will raise static compression. The issue with using copper is the block must be completely flat or there is a risk of leaking. The tool used to deck the block at the factory can score the surface leaving grooves. A gasket spray could be applied, but there is still a risk of compromise.
Note the impressions (lines) in this copper MINI gasket and the residue indicating blow-by.
Old Mar 9, 2010 | 03:25 PM
lbaron's Avatar
lbaron
The only good thing I've seen with solid copper gaskets is that you can get them in any thickness that you want. Other than that, I would not recommend them cause if your motor runs too hot (not overheating by any means) it will blow the gasket and you'll have to replace them. I had a friend that went through a few in one summer of racing.
-Luke
Old Mar 10, 2010 | 01:00 PM
Dave.O's Avatar
Dave.O
For the labor cost of just replacing a head gasket that has not even failed you could just by a new stock gasket and put a BVH on your car and that will absolutly increase your power much more than any all copper gasket.
I am just saying since you are thinking about taking the head off and there is nothing wrong with the current gasket. If you are looking for more power why not add a nice new BVH on top of the new head gasket. (Big Valve Head)
Thats is what I told "her".
iclancy82
Jan 2, 2021 08:59 PM
sempaipaul
Oct 26, 2015 05:56 PM
3L6
Sep 21, 2015 06:21 PM
Sep 2, 2015 09:05 AM
