Where can I get this part? please help!
My sisters 02 cooper S is a manual tranny with the oil pressure relief spring thing in the picture, which is broken, missing some clips that hold it in place in the filter housing. Oil lamp comes on at idle because of it! I cant find this part anywhere does anyone know where to get one or have one to sell?
http://www.realoem.com/bmw/showparts...97&hg=11&fg=30
lists the part numbers.. looks like you're probably #s 6-10
here's the valve itself @ allminiparts.com, $14:
http://www.allminiparts.com/products...411485165.html
search on there for the other parts numbers listed in the exploded view on realoem..
good luck!
good luck!
The pressure sensor from the oil filter housing... The part you have there cannot be obtained separately, it doesn't even show up on RealOEM. You'll actually have to buy a whole new housing. This has happened to others before.
Next time, be sure to lube the rubber on the oil filter so that it slides on the pressure sensor.
thats what I was afraid of.. it was like this when we bought the car have been able to get it into position a couple of oil changes but cant get it to work this time. do you know where I could get a good one without paying $300?
thanks for all your help guys!
(916) 635-5900
You can try these guys - they're in CA - Rancho Cordova.
I've used them for Miata parts in the past.
ryGuyMCS
Oct 20, 2015 02:24 PM
nomar116
Aug 21, 2015 04:36 PM
