Brake lights dont light up.
Old Feb 16, 2010 | 04:07 PM
dustinhxc's Avatar
dustinhxc
I have a 2004 MINI Cooper S. Clear taillights and chrome bulbs. the running lights work but when I press on the brakes only my 3rd brake light under the tailwing works. i checked the brake light fuse. any reason they would be lit while running but not get brighter once the brakes are pushed? could it be the bulbs? thanks.
Old Feb 16, 2010 | 07:56 PM
dustinhxc's Avatar
dustinhxc
:[ maybe ill buy a normal red bulb and see if it gets brighter when i press the brakes....
Old Feb 16, 2010 | 08:27 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
It should be a 7528 which is the same as an 1157 bulb.
Old Feb 16, 2010 | 08:32 PM
rkw's Avatar
rkw
The bulbs are dual filament. One filament only illuminates for the brake and the other only for the running light. The brake filament can burn out and the running light filament can continue working (or vice versa).
So the bulbs could be the problem, but it would be odd if the brake lights on both sides suddenly stopped working at the same time. If that's what happened, something else might be causing the problem.
Old Feb 17, 2010 | 03:11 AM
dustinhxc's Avatar
dustinhxc
Thank you both of you!
Old Feb 17, 2010 | 11:59 AM
dustinhxc's Avatar
dustinhxc
I bought new Sylvania LL bulbs and red bulb covers and they work running and pushing on the brake. Thanks guys! Ill let you know if those stop working ever.
Dec 23, 2015 10:36 AM
TunedGP
Oct 1, 2015 04:18 PM
AZN Optics
Aug 16, 2015 11:52 PM
