Introducing: BSH Speedshop
Old Feb 9, 2010 | 12:09 PM
BSH Speedshop's Avatar
BSH Speedshop
Contact:
Phone: 602-606-7973
Email: sushil@bshspeedshop.com
Aim: Sush BSH Mini
Old Feb 9, 2010 | 12:11 PM
BSH Speedshop
Design Requirements:
When looking at the current motor mount offerings this was a simple decision. Band-aid a stock part with stiffer bushings, or re design it to be a performance part from scratch. Not everyone has the machines and tooling that we do and as such the former seems to be the approach. By recreating the part with performance in mind we have tackled the sloppy factory main bushing, eliminated the soft secondary bushing, and strengthened the part as a whole by creating a new billet case to replace the cost minded factory extrusion.
Designing the part was the first step, keeping it livable however is a completely different task. BSH has spent considerable time in choosing the optimal durometer to enhance the performance and fun aspect of the vehicle without degrading from the everyday usability. The bushings included are provided to BSH by a supplier of bushings to multiple OEM’s. BSH has made available two different durometers, street and race, which can be selected at the time of ordering.
All motor mounts come with a standard military grade hard black anodized finish to give the product the look it deserves and preserve the body against the elements.
Now Available:
BSH is pleased to be the first to offer this product to the community. These products are now available to begin shipping. Pricing is set at $119.99 and is available with free shipping through our website.
To purchase a BSH Billet Lower Motor Mountclick the link to be directed to our secure website. We accept Visa, Mastercard, Discover, Amex, and Paypal through our website.
Contact:
Phone: 602-606-7973
Aim: Sush BSH Mini
We thank you for your support and look forward to working with you from start to finish on your project.
BSH Speedshop
Power and reliability, the goals of all performance enthusiasts. We live this mentality here at BSH. When looking at increasing both simultaneously, few parts do so as well as the addition of a catch can. On paper it’s an oil catch, but like most things in life it is the little things that add up.
BSH takes their catch cans seriously. Externally all cans are welded together to avoid the all to common leaking issues bolt together setups have. Internally better than the competition by incorporating mesh baffling to slow down oil vapors so they cool and condense inside the can instead of your charge piping/engine. All fittings are made with push lock fittings and hose to avoid the use of a dozen unsightly hose clamps. Integrated drain fittings make maintenance a breeze.
All of the BSH catch can systems are designed to be completely reversible and mate up with all factory pcv connections utilizing vehicle specific billet connectors. The R56 catch can kit ships complete with a laser cut stainless steel bracket that will allow two different positions to be used for mounting depending on whether or not you are using the factory intake system.
Now Available:
BSH is pleased to be the first to offer a product of this caliber to the community. These products are now available to begin shipping. Pricing is set at $169.99 and is available with free shipping through our website.
To purchase a BSH R56 Catch Can Kit click the link to be directed to our secure website. We accept Visa, Mastercard, Discover, Amex, and Paypal through our website.
Contact:
Phone: 602-606-7973
Aim: Sush BSH Mini
Old Feb 9, 2010 | 12:12 PM
BSH Speedshop
Work smarter, not harder. A saying that we try and apply to every other aspect of our lives, why should modifying cars be any different? One of the single most important and common modifications to your turbocharged vehicle is the addition of a boost gauge. Since its something you basically have to do, why hasn’t there been an easier way to do it?
When looking at making its boost gauge adapter BSH gave this view strong consideration. Since we knew a lot of customers would by shopping for them we wanted to make sure ours stood out as the most simple to install and also the one that had the least potential for additional issues like what can be caused when there is a leak around a critical sensor.
Introducing the BSH Direct Dual Port Boost tap. Designed and manufactured in house on our CNC lathe this is your all in one easy to use boost tap system. Twin ports allow for you to use a boost gauge, blow off valve, methanol injection etc without needing a whole mess of T’s. Strategic positioning in an easy to access spot directly off the intake manifold makes adding or swapping lines a breeze.
As an added plus we built in a block off system to remove the ability of the PCV system to dump vapors directly back into the motor. (Yes we tested it! Yes it works!)
Now Available:
BSH is pleased to be the first to offer this unique product to the community. Pricing on the R56 Direct Dual Boost Tap System is set at $59.99.
To purchase a BSH Direct Dual Boost Tapclick the link to be directed to our secure website. We accept Visa, Mastercard, Discover, Amex, and Paypal through our website.
Contact:
Phone: 602-606-7973
Aim: Sush BSH Mini
BSH Speedshop
You cant always re-invent the wheel, but with the right manufacturing processes, you can make one a little bit more round.
BSH takes their catch cans seriously. Externally all cans are welded together to avoid the all too common leaking issues bolt together setups have. Internally better than the competition by incorporating mesh baffling to slow down oil vapors so they cool and condense inside the can instead of your charge piping/engine. All connections are made with push lock fittings and hose to limit the use of hose clamps that would otherwise clutter up the bay. Integrated drain fittings into the base of the catch can makes maintenance a breeze.
All of the BSH catch can systems are designed to be completely reversible and mate up with all factory pcv connections utilizing vehicle specific billet connectors. The R53 catch can kit ships complete with a laser cut stainless steel bracket that will for direct mounting to an easy to access bolt in the engine compartment.
Now Available:
To purchase a BSH R53 Catch Can Kit click the link to be directed to our secure website. We accept Visa, Mastercard, Discover, Amex, and Paypal through our website. Pricing is set at $149.99 and is available with free shipping through our website.
Contact:
Phone: 602-606-7973
Aim: Sush BSH Mini
Old Feb 9, 2010 | 12:13 PM
BSH Speedshop
Designing the part was the first step, keeping it livable however is a completely different task. BSH has spent considerable time in choosing the optimal durometer to enhance the performance and fun aspect of the vehicle without degrading from the everyday usability. The bushings included are provided to BSH by a supplier of bushings to multiple OEM’s.BSH has made available two different durometers, street and race, which can be selected at the time of ordering.
Now Available:
To purchase a BSH Billet Lower Motor Mountclick the link to be directed to our secure website. We accept Visa, Mastercard, Discover, Amex, and Paypal through our website. Pricing is set at $129.99 and is available with free shipping through our website.
Contact:
Phone: 602-606-7973
Aim: Sush BSH Mini
Old Feb 10, 2010 | 04:35 PM
BSH Speedshop
Get the full BSH line and more at..
rrglo
Sep 16, 2015 02:59 PM
mikeyb74
Aug 24, 2015 12:13 PM
minipopkart
Aug 13, 2015 05:22 AM
