Navigation & Audio Aftermarket Stereos
Old Nov 29, 2009 | 04:23 PM
blue beauty's Avatar
blue beauty
Aftermarket Stereos
I am looking at replacing my Harman Kardon stereo with an aftermarket stereo. Can I use the speaker system that's already in it? I need to know what parts I will need, so if anybody can help me I would really appreciate it! I have a 2004 Mini Cooper S and my amplifier is blown. Thanks, everybody!!
Robin
Old Nov 30, 2009 | 01:32 AM
Eric_Rowland's Avatar
Eric_Rowland
Short answer is 'no'.
The H/K uses the same head unit as the other systems, but uses different speakers (2ohm? 4ohm??) and the wiring runs from the HU to the amp (in the rear of the passenger side) and then out to the speakers.
There was a thread here not too long ago about an amp that would replace the H/K, but I can't seem to find it.
Old Nov 30, 2009 | 07:02 AM
blue beauty
Thanks for your help Eric. I'll keep investigating. I don't want to pull the speakers just for an aftermarket unit. It would ruin the way it looks inside. If you do find that post, can you please forward it to me? Thanks!
Old Nov 30, 2009 | 09:17 AM
Eric_Rowland
Guess I was tired last night - it's right here. Sounds fairly technical though, and not significantly cheaper than a used H/K amp after all the components are purchased.
Old Nov 30, 2009 | 11:29 AM
GBMINI's Avatar
GBMINI
You'll be able to install aftermarket speakers BEHIND the grilles, so it doesn't look any different once the panels are back on.
An amount of wiring, to get signals from the HU to the speakers (since as said the wires to speakers currently go from rear where HK amp is located), but not impossible by any means.
Old Dec 1, 2009 | 08:31 AM
Act_04's Avatar
Act_04
https://www.northamericanmotoring.com/forums/navigation-and-audio/178866-upgrade-amp-speakers-head-unit-need-advice.html
Even though you are looking for a replacement and this other guy is looking for an upgrade, the same information may help you out.
RobbyD
Jan 29, 2019 01:22 PM
Doc Pain
Oct 28, 2015 07:09 PM
Qik420
Oct 4, 2015 08:19 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
