R57 Is this normal Handling Q
Old Nov 5, 2009 | 08:18 AM
RM5's Avatar
RM5
The car handles good BUT when in a turn and smallest pothole or bump the car hops. scaryis it the run flat tires? or is this normal. I know I can't have this. any suspension changes needed?
TIA
Old Nov 5, 2009 | 08:29 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Its normal for the R56/55/57. I believe that changing the bushings helps. Check out the suspension forum for more information on how to control this problem.
Old Nov 5, 2009 | 08:43 AM
howie289's Avatar
howie289
Check your tire pressure. My car did this and it improved after I adjusted the tire pressures (the dealer delivered the car with 50psi in all 4 tires). Replacing runflats with non-RFs will help also.
Colt45Magnus
Aug 27, 2024 05:03 AM
CSC_R53
Sep 9, 2015 03:12 AM
Suspension Products
Sep 3, 2015 09:41 AM
