Navigation & Audio Stereo Volume Modulation on HK, any ways to turn it off??
Old Oct 18, 2009 | 09:47 AM
WizardEyes's Avatar
WizardEyes
is there anyway to turn off the volume modulation in the stock HK Deck i hate getting on the freeway only to loose most of my bass and the volume seems to be cut in half just about. i dont wana put an aftermarket in and loose the stock look but is there anything else i can do about it???
Old Oct 18, 2009 | 10:42 AM
MINIdave's Avatar
MINIdave
Yes, if you can find it in the screens, you set the amount of change to 0.
Do you have the manual? If not, I'll try to find mine later and tell you which screen to go to.
Old Oct 18, 2009 | 11:37 AM
GBMINI's Avatar
GBMINI
The SPEED VOL adjustment on non-HK MINIs controls the amount of auto adjustment - but it has no effect on HK stereos, and was removed from the menus after early builds.
The effects you describe did not happen with my car. Try setting both BASS & TREBLE to FLAT / 0, and see if the effect still occurs.
Old Oct 18, 2009 | 04:08 PM
MINIdave's Avatar
MINIdave
My '03 with HK has this function, I'll try to check out how to get to it in the menus...
Old Oct 18, 2009 | 04:16 PM
WizardEyes's Avatar
WizardEyes
i got into the menu like the book says but it only has NAV + OR - Options not speed volume like the book says
Old Oct 18, 2009 | 05:22 PM
GBMINI's Avatar
GBMINI
Please read ...
Old Oct 20, 2009 | 11:31 AM
Supercoop55's Avatar
Supercoop55
The speed compensated volume is not the issue here. What is going on is the built in compressor that protects the amp/speakers from distorted output and overload conditions will turn overall volume down when bass is boosted past a safe level for that paticular system. I guess a better way to say that is the the system limits the loudest element in the music to a safe level. That is why you hear the ratio of volume between bass/mid/high change at max volume. To my knowledge this feature is not defeatable. The speed comp vol adj will increase volume as the speed/noise of the car increases. That is adjusted by holding the music button until menu appears. Scroll to it and adjust,
Shane Wendel
Aug 17, 2015 05:49 PM
yashmack
Aug 15, 2015 03:11 PM
Glamrock
Aug 11, 2015 06:28 AM
bctf1
Aug 6, 2015 12:55 PM
