MINI5280 The Motoring Society of the Rocky Mountain Region. Visit the club site at www.mini5280.org and Event Calendar.
emission problem
Old Oct 1, 2009 | 07:37 PM
CooperRs's Avatar
CooperRs
emission problem
Hey Guys, Having problem getting her to pass emissions. Any Ideas???
https://www.northamericanmotoring.com...nightmare.html
Richard
mayershults@gmail.com
Old Oct 1, 2009 | 09:55 PM
old81's Avatar
old81
M6
I sent Richard over here for some direct input from the MINI5280 R53 owners. He is real close to solving the problem, but NTY (not there yet).
bahman, miniconcarne, intercoolest, thoughts on this one?
I think O2 sensor and the aftermarket exhaust, cat-converter is compounding the problem, but what do I know.
Don
Old Nov 22, 2009 | 01:50 PM
intercoolest's Avatar
intercoolest
Rich:
Sorry to take so long to reply. I had something similar happening to Panther. Then 2 weeks ago my Header/Cat welded assembly broke in two & sounded like a wimpy NASCAR.
Back together w/ a used unit from Clint Cope in CA. & Panther is one Healthy Cat again!
Before the obvious was detected, I had SES light w/ 4 codes that never made sense. Simultaniously it read: running rich, low MAP voltage, Traction Control alarm & O-2 sensor stuck lean. August RMW Dyno Tune day at MAC, Panther's runs were aborted 4 times reading too lean & low boost.
Panther is running so strong now that my tires will break loose in 1st & 2nd gear just hammering on the skinny pedal w/ clutch fully engaged (700 ft elevation here in Tulsa helps).
Now that root cause is understood, Tuners accross the country are telling me that this is common. My old exhaust lying next to the replacement used unit showed not only the failed weld, but all other welds were defective.
Check yours for the same exhaust leak.....
Mike
Now I realize that the exhaust was leaking fresh air into the system just ahead of the O-2 sensor & confused it's brain.
Old Nov 22, 2009 | 01:51 PM
intercoolest
Call me or PM on the failure for more details.
Mike
Old Nov 23, 2009 | 08:06 AM
jckonrad's Avatar
jckonrad
If this is the case I have some headers for sale that will cost much less than if you go through the dealership. PM me if your interested.
Old Nov 23, 2009 | 08:12 AM
BLU-BY-U's Avatar
BLU-BY-U
Rich solved his problem a little while ago. He finally passed, here is the link to that Passed or his post
"To update everyone on my ordeal: Following the advice of many on NAM, I replaced the precat O2 sensor and run a 1/4c of Acetone in a tank of gas. When back to emission (5th time) and FAILED. The Nox reading actually when UP from 1.61 to 2.16. So, Very Frustrated, I returned to my new friends at Peak Eurosport. Changed to "colder" plugs and put 3 gallons of 100 octane fuel. They strongly suggested, getting the car good HOT and if there was a line to go back another time. Just this morning, Drove to a emissions place on the opposite side of Denver (Getting her Good and HOT). When I arrived, there was a little bit of a wait but, still decided to wait, maintaining about 2000rpms (keeping up the HEAT). When I got to the bay, I told the guy that this was my sixth time and needed her to pass. He smiled and said "I'll make it pass". There must be some kind of trick because, I did pass with a 1.06 Nox. When I pulled away, the tester honked from the car that he was testing and gave me a thumbs up."
embiggenedmini
Oct 15, 2015 12:36 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
