Navigation & Audio Question after changing head unit
Old Sep 28, 2009 | 12:58 PM
R53's Avatar
R53
I had the oem headunit (phillips) removed and had a pioneer one installed. Everything works perfectly fine but i noted that when you turn the parks on, the speedo/tachometre & centre console lights up, but excluding the the A/C middle section (i have the A/C middle section with the big digital circle in the middle) only once the key is in the ignition and is turned on, then it illuminates. IS this normal?
also, the buttons behind the steering wheel, do they become dummies once the original headunit is removed? mine no longer works.
Old Sep 30, 2009 | 07:44 AM
Bruce graham's Avatar
Bruce graham
You would need this http://www.pac-audio.com/productDeta...&CategoryID=29 if your unit is set up for it.
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
yashmack
Aug 15, 2015 03:11 PM
veevsato
Aug 5, 2015 04:42 AM
