R98 webspoke on 03 Mini?
Old Sep 20, 2009 | 11:05 AM
ulrichd's Avatar
ulrichd
Will the R98 webspoke wheels from a later (05,06) Mini fit an earlier car? I know there were some changes to the lug bolts.
Thanks.
Old Sep 20, 2009 | 11:10 AM
ulrichd's Avatar
ulrichd
Never mind, found the answer.
In about May 2006 the bolts used on the MINI wheels were enlarged from 12mm to 14mm.
Old Sep 20, 2009 | 11:13 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks.
R98 webspoke is 17x7"
It will fit any MINI all years.
Note that if you put them on an MC you might notice-
Harsher ride if you have runflats installed due to stiffer sidewall of runflats or stiffer sidewall of 205/45-17 tires. Also if you had non runflats before and then use 17" runflats it might be harsher.
There are many good 17" non runflat tires but difficult to have a spare in 17" size to carry for any MINI.
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
Accessory Products
Aug 10, 2015 01:35 PM
Dashdog
Aug 10, 2015 06:17 AM
