Lower Console Gauges and Lighter failing?
Old Sep 10, 2009 | 08:22 PM
AggieMini11's Avatar
AggieMini11
So I was driving and made a U turn when my FM Transmitter just turned off randomly. I noticed then that the Oil Temp Gauge and the Voltmeter were on (lights up) but at zero getting no readings. So is the lower half of my console dead? Any help would be GREATLY appreciated
Old Sep 10, 2009 | 10:43 PM
rkw's Avatar
rkw
The lower console gauges get power from the cigarette lighter. The first thing to check is the fuse for the lighter, F32. If it's blown, pull your FM transmitter before replacing the fuse because it may have been the cause.
Old Sep 11, 2009 | 01:56 AM
AggieMini11
Nice! My cigarette lighter is really loose. Like when I pull my FM transmitter out, I have to hold my lighter in so it doesnt get pulled out with it. Maybe the cause?
Old Sep 12, 2009 | 11:33 AM
rkw's Avatar
rkw
The loose socket is just the tightness of the fit with the hole in the center console plastic, and not directly related to anything electrical. You should check fuse F32 first. If that wasn't the problem, you'll probably have to pull the console cover to check whether any of the connections on cigarette lighter (which includes connections to the gauges) came off.
Old Mar 31, 2012 | 03:33 PM
RideSolo's Avatar
RideSolo
Is the loose socket common in these and, if so, is there a reasonable way to repair it? I assume you have to take that console cover off; how is it secured into the console?
Cory
'02 MC, CB/CB, 5-Speed
loop4re7
Oct 5, 2015 09:53 PM
sevin
12
Sep 4, 2015 01:50 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
OutMotoring
Aug 6, 2015 09:32 AM
