2009 JCW - SCCA STX Wheels
Old Sep 3, 2009 | 01:43 PM
Wizeguy9999's Avatar
Wizeguy9999
I'm trying to see if anyone knows if 17x8 Motegi Traklite 2.0's will fit on a 2009 JCW? I want to find a very wide rim that is light, and I'm curious if anyone thinks those will fit.
Old Sep 3, 2009 | 07:57 PM
e30r56's Avatar
e30r56
Offset and what size tire?
Old Sep 3, 2009 | 10:06 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Yes they will. They are 17x8 42ET. Not sure what tire you are running but Hoosier 225/40-17 fit, the V710 215/40-17, NT01 225/45-17 also fit. On my car and R53 the 225/45-17 Toyo R888 did not fit (taller and wider than tires mentioned above) without cutting some wheel well and fender trim, but the R56 has alot more space in wheel well than R53. Which color Motegis do you have by the way? I have 2 sets a Black w/ Machine Polished Lip and Flat Teflon Black, well they were flat black now they are all Polished Aluminum.
Take a look: https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/174668-project-project-motegi-traklites-2-flat-teflon-black-stripped.html
Old Sep 4, 2009 | 09:37 AM
Wizeguy9999
I don't have them yet. I'm trying to decide on a purchase for next year. The STX class doesn't allow anything with a treadwear below 140, so Hoosiers and V710's are out of the question. I'll probably end up buying some Kumho Exsta XS's which seem to be a very fast street tire for autox.
Any suggestion of tire size with a 17x8 42mm offset rim?
Old Sep 5, 2009 | 01:37 AM
howsoonisnow1985
Grassroots Motorsports re: Kumho XS
The Kumho XS only good size for the 17x8 42ET wheel might be the 215/45-17, although the 225/45-17 may fit? I'd prefer they had a 215/40-17 but I would really wish they had 225/40-17, cause the tall O.D. will kill your gearing even further. The Dunlop Star Spec and YokohamaAD08 both come in 215/40-17. Also, the preferred auto-x set-up is on 15's but don't know what 15's would clear your JCW/Brembos. Here is more info about the XS.
From the June 2009 issue: Tires were tested in 15 inch sizes on a ST Honda Civic (Andy Hollis). All tires were shaved to 3/32nd and test performed on an Autocross set up. Tires sizes are 205/50/15 (RT-615, R1R, RE-11, XS), 195/50/15 (RE-01R), 195/55/15 (Z1 SS)
Here is a summary of times from worst to first.
6th-Falken RT 615-Mean time: 35.302sec Quick time 35.125sec
5th-Dunlop Star Spec-Mean time: 35.209sec Quick time 35.061sec
4th-Toyo Proxes R1R-Mean time: 34.522sec Quick time 34.452sec
3rd-Bridgestone RE-01R-Mean time: 34.478sec Quick time 34.430sec
2nd-Bridgestone RE-11-Mean time: 34.266sec Quick time 34.238sec
1st-Kumho Ecsta XS-Mean time: 34.170sec Quick time 34.030sec
Part 2 August 2009 issue: Same car and same setup.
Tires sizes are 205/50/15 (AD08, R1R, XS), 225/45-15 (RE-11)
4th-Toyo Proxes R1R-Mean time: 35.356sec Quick time 35.264sec
3rd-Bridgestone RE-11-Mean time: 35.398sec Quick time 35.262sec
2nd-Yokohama AD08-Mean time: 34.972sec Quick time 34.827sec
1st-Kumho Ecsta XS-Mean time: 34.728sec Quick time 34.541sec
Sexual Chocolate
Mar 31, 2019 08:02 PM
nomar116
Aug 10, 2015 11:24 PM
2manyhobbies
Aug 9, 2015 06:02 PM
nomar116
Aug 9, 2015 09:42 AM
marendt428
Aug 8, 2015 04:44 AM
