R56 Oil Cooler Kit....................... From M7
R56 Track enthusiasts... this is directed at you! (But of course it's beneficial to anyone that gives their Cooper S a little exercise
During high stress or high performance driving, the engine oil can reach temperatures upwards of 230º F! This can be very dangerous to internal parts such as piston rings and cam bearings because heat can partially or completely deteriorate the oil properties. In turbo applications such as the R56, the oil gets dangerously hot and can cause damage to the engine and lower the life expectancy of the turbo itself. With the R56's aluminum block, it's important to keep the oil cool for the sake of the engine's longevity. By replacing the stock oil cooler with the unit offered in this kit, you can significantly bring down the oil temperature during hard driving to increase the life of your engine.
The M7 Oil Cooler Kit (R56) is available now by visiting www.M7Tuning.com or by calling our office at 562.608.8123
The kit costs $538 and includes everything you need to keep your oil temperatures down in demanding situations.
)During high stress or high performance driving, the engine oil can reach temperatures upwards of 230º F! This can be very dangerous to internal parts such as piston rings and cam bearings because heat can partially or completely deteriorate the oil properties. In turbo applications such as the R56, the oil gets dangerously hot and can cause damage to the engine and lower the life expectancy of the turbo itself. With the R56's aluminum block, it's important to keep the oil cool for the sake of the engine's longevity. By replacing the stock oil cooler with the unit offered in this kit, you can significantly bring down the oil temperature during hard driving to increase the life of your engine.
Kimolaoha
Jul 5, 2023 01:04 PM
Lex2008
Aug 16, 2015 08:33 PM
Aug 11, 2015 09:01 AM
