R50/53 Rear Wheel Alignment
Old Aug 16, 2009 | 05:49 PM
ZigZagN's Avatar
ZigZagN
My 2003 Mini S has 82,000 miles. The inside of the reat tires are wearing out much faster than the rest of the tread. On my Corvette, there are cam bolts that can be used to adjust the suspension, but I don't see any way to adjust the rear suspension on the Mini. Am I missing something or how is the rear suspension adjusted?
Randy
Old Aug 16, 2009 | 05:56 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Sorry Randy, your 03 doesn't have any camber adjustment. MINI didn't add rear camber adjustment till Jan 05 on MINI'. You will need a set of lower arms to get the rear back to spec. If you need a set I'd check out the TSW arms any of the aftermarket arms will help you.
sevin
May 2, 2026 06:11 AM
maestro39
Oct 27, 2015 02:38 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Minibeagle
Aug 13, 2015 10:00 AM
