Need Help with Wheels
Old Oct 22, 2003 | 07:21 PM
mbur1024's Avatar
mbur1024
Getting new wheels for 2004 MCS. I am concened about offset and proper fit. I want the HP Racing EVO wheel 17x7 size, does anybody know if they are any good and does anyone know if a 35 offset will cause a problem when the factory offset is 50? Is the wheel too far in the fender or does it stick out. I plan on running 215/45/17 S03 tires (from the tirerack of course). Will it rub? If the offset is wrong how about ASA AR1 wheels with a 42 offset? Does 7 MM make that much difference. Finally, any thoughts on KONIG Imagine wheels?
Thanks for help!
Old Oct 23, 2003 | 01:43 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If you are going to keep your stock springs then 35 offset will rub.
ASA AR1 with 42 offset will do better.
Read this first
see Alex@tirerack and RandyBMC's posts
https://www.northamericanmotoring.co...mp;topic=14882
Old Oct 23, 2003 | 07:06 AM
kenchan's Avatar
kenchan
minihune- huh, would you explain this? 35mm offset is going outward
so i think he would rub his fenders than rub his springs. if it was 55mm offset
then yah, maybe it might rub. did i read your post correctly?
35 imo is too aggressive, might want to try 48-40 range and use 205/45/17's
Old Oct 23, 2003 | 02:05 PM
Alex@tirerack's Avatar
Alex@tirerack
I agree 35 is a bit agressive
Alex
Old Aug 9, 2005 | 07:27 PM
D_Nyholm's Avatar
D_Nyholm
Sorry to drag up such an old thread, but I really want the 17x7 HP evo's though with this information it sounds like it is impossible. Has anyone mounted the 17x7's with no problems at all??
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
