Suspension h-sport rear control arms weight
Old Jul 30, 2009 | 01:23 AM
catnjosh15's Avatar
catnjosh15
does anyone know the weight difference between the h-sport rear control arms and the stock ones?
Old Jul 30, 2009 | 07:29 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
The Hsport are heavier than the stock ones. But what does it matter? The Hsports will last forever and give you the adjustment the stock ones can't. And if you can install lighter control arms and actually tell a difference you are more in tune with your car than anyone, and should be an engineer for a major manufacture. The weight isn't worth thinking about it.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Nov 7, 2009 | 10:56 AM
norm03s's Avatar
norm03s
What is the recommended lube for those Hsports.
Old Nov 10, 2009 | 04:27 AM
norm03s's Avatar
norm03s
Answer:
Any non-lithium based moly grease. A Special silicon grease for polyurethane can be purchased from Hotchkis. Item 3101.
Old Nov 10, 2009 | 06:25 PM
KC Jr 54's Avatar
KC Jr 54
I would highly suggest the TSW arms. Beefier, and the grease fittings actually work!!! And the H-Sport bushings are semi known to not lasting long term.
I currently have the H-Sports too...
Also the SPC arms look extremely nice.
Old Nov 10, 2009 | 06:31 PM
BlimeyCabrio's Avatar
BlimeyCabrio
I'm a big TSW fan in general... but their arms are so new, no telling how long the more rubbbery bushings will hold up vs. the H-Sport ones. I haven't heard any H-sport failure stories - I'm not sure what "semi-known" means?
I love my H-sports.
Old Nov 10, 2009 | 06:37 PM
KC Jr 54's Avatar
KC Jr 54
"semi-known" meaning it is hit or miss. TSW supported those arms a lot, but after several of their customers cars had bushing failure with the H-Sport is the reason they developed their own.
Guys at TSW are expects with poly at this point lol.
Yes they are new, but they are also a great company from head to toe. They have also been tested for several months on select cars.
Old Nov 10, 2009 | 06:47 PM
BlimeyCabrio
I'm not questioning TSW - love them.
Just that I know folks who have used the H-Sport poly bushing arms on their track cars for years with no issues.
Several months of testing is good... but may not indicate what one might see in a couple of years. That's my point.
Old Nov 10, 2009 | 07:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Little FYI, The TSW Control arms don't have any grease fittings, so you can't say they work better.
And for Hsport control arms not lasting that is 100% untrue. I've been racing on them for years and not worn out one of their bushings, Also that is my most popular brand I sell and I've sold a ton over the years. I've NEVER had a customer not even one have a problem with any of the Hsport control arms. I right now have a customer that has had them upper and lower on his car since 2003, over 150k on his car, and autoX's every other weekend. Hasn't worn one of them out yet. So can't write them off, they are GREAT.
Old Nov 15, 2009 | 12:40 AM
haygood's Avatar
haygood
So, nobody is going to weigh them? Not even vendors who have different ones in stock? I get the points you have made, but I'd also like to know the answer to the question.
Old Nov 16, 2009 | 07:19 PM
MINICHEF's Avatar
MINICHEF
Helix are most likly the lightest followed by Alta, The H-sports are heavier than stock, so most likely in the 4+lb range and the super beefy TSW are running a little hevier than that. We weighed Helix, alta, stock and TSW but I forgot to right down the weights
Old Nov 16, 2009 | 09:16 PM
WayMotorWorks
Vendor
I'll weight some tomorrow and post back.
Old Nov 17, 2009 | 09:04 AM
WayMotorWorks
Vendor
Ok we have weights for you.
Helix 1lb 12 oz each
Hsport 3lbs each
TSW 4lbs 1 oz each
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
