Kappasphere has what your MINI needs!
Old Jul 21, 2009 | 03:50 PM
Kappasphere's Avatar
Kappasphere
Kappasphere's got what you need to make your MINI more fun and better prepared for the street AND track! We offer performance parts from NM-Engineering, Brey Krause, Hawk Performance and other great manufacturers. We also offer our own great solutions for the MINI.
You can visit our website at: www.kappasphere.com/mini
or call us at: 951-296-6762
______________________________
If you love spirited motoring , (like we do!) then, you'll love NM-Engineering's SS Brake Lines. These braided, stainless steel brakes lines will not expand under heavy use like the stock rubber lines will.
Heavy braking generates a lot of heat in brake rotors, pads, calipers and brake fluid. All of that heat causes the stock rubber brake lines to expand resulting in a loss brake pedal feel and overall performance. NM's SS Brake Lines solves this problem.
These SS Brake Lines are made with silicone protected stainless steel, an inner Teflon tube and rubber grommets that perfectly secure the lines to your stock strut. They are DOT approved and will increase durability and deliver positive, firm pedal action.
SS Brake Lines are IN STOCK and ready to ship!
_______________________________
Hawk performance has the perfect brake pad setup for your tracked MINI. Hawk has tested numerous combinations of pads and found the best setup. Using Hawk's DTC60 fronts and HPS rears, you'll have excellent balance, control and stopping power on the track. Found out what professionally setup brake bias feels like!
HAWK DTC60 front brake Pads
HAWK HPS rear brake pads
NM's Adjustable 22mm Rear Sway Bar is properly engineered like every part they offer. This sway bar will make your R56's handling very neutral. Body roll is significantly reduced making your MINI really stick to the road. The difference this bar makes is quite remarkable.
Like always, NM has engineered every little piece of their Adjustable 22mm Rear Swar Bar to be the best as possible. Machined 6061 alloy brackets are hard anodized and far superior to stock.
The bar itself has 5 different stiffness settings with machined ends to ensure the strongest and most durable design was implemented. The bar itself is made out of 4130 Chromoly for superior fatigue resistance, high tolerance & zero-memory.
This great bar is IN STOCK AND READY TO SHIP!
_________________________________
If you track your first gen MINI ('02-'06), a fire extinguisher mounted in an easy-to-reach position is a must-have safety feature. Kappasphere has a great setup for you. The H3R Halotron 2.5 lb Fire Extinguisher is one of the best on the market and is the same extinguisher we offer for the Lotus.
This extinguisher, along with the Brey-Krause Mounting Bracket, looks great and can save your car if something were to go wrong. Peace of mind AND a racy look!
Brey Krause is a leader in providing safety equipment for street and track use for a variety of cars. This Universal Fire Extinguisher Mount is a great example of one of their high-quality solutions designed to make your motoring experience as safe as possible. Whether you're in hot weather or not, street or track, it's smart to carry a fire extinguisher on board. Safety aside, a fire extinguisher always makes your passengers think what you do on the weekends !
Look cool and be safe!
CLICK HERE TO LEARN MORE & TO ORDER!
Old Jul 21, 2009 | 03:58 PM
Kappasphere
Street Ceramic Brake Pads - '02-'06 MINI
You will get everything you need for street use with these pads! Hawk has engineered these ceramic pads to deliver on every level.
  • Extremely quiet - engineered to reduce brake NVH (Noise, Vibration, and Harshness)
  • Increased stopping power
  • Increased rotor life
  • Extended pad life
  • Ultra-low dust
  • Stable friction output
  • Ideal for import and domestic sportscars
What more could you ask for in a brake pad? We have these pads in stock and ready to ship in FRONTS & REARS.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
