Would these fit?
Would these fit?
To the wheel guru's out there....would these fit?
16" Staggered (2-16X9 2-16X7.5)
Mirror finished 1.25" lip FRONT
Mirror finished 3.0" lip REAR
Center bore 57.1
4x100
ET 20 ALL AROUND (actually the 16X9 might be ET 10 but need to confirm)
Center bore 57.1
4x100
The 9" wide wheel will not fit anywhere on the car, some scientists believe. The offset for the 7.5" wide wheel seems too low, so the wheel will stick out too far. I think the maximum width is 7.5 or 8" and the offset needs to be between 35-45.
16X9 seem to fit? Are the offset's the issue? Car is stock height and might be lowered.......any other opinions?
http://www.motoringunderground.com/f...ad.php?t=12080
16x9 et20 or 10? Yeah, good luck with that... However, it will fit if you're not lowered and you put maybe a max 30 profile tire on. You'll have at minimum 3 inches of tire out beyond your bodywork... I'd also hope you're not still under warranty, because something in your suspension will inevitably break, and it wouldn't be covered if you drove up to the dealer with those bad-boys on... Buy hey, if that's your thing, go for it.
trw92a
Aug 26, 2015 01:47 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
