ALTA Cranks out the deals on Crank Pulleys!!!
Old Jul 3, 2009 | 10:49 AM
ALTA_JOHNL's Avatar
ALTA_JOHNL
CRANKIN1727
Come one come all to the BEST deal on ALTA crank pulleys EVER!! I got to work before the boss did today and made a coupon code for everyone to get 20% off all ALTA Crank pulleys! For the R53 we have a choice of stock diameter, 2%, and 3% underdrive. For the R56 we offer a lighweight stock drive pulley. COUPON CODE IS CRANKIN1727 Here is a great description of the pulleys..
"Improve throttle response, horsepower at the wheels and your sense of adventure. With an entire series of black anodized, lightened Crank Pulleys from ALTA Performance it’s easy to increase response, reduce drag and hit the road fast.
The ALTA Performance™ lightened crank pulleys for the MINI Cooper R53 are engineered to reduce rotating mass, increasing horsepower and torque.
The ALTA Performance™ pulley achieves power and performance by reducing the rotating mass of the crank assembly. Made from 6061T6aluminum and weighing in at .65 lbs,the ALTA pulley™ is more then 2.3lbs lighter then the stock crank pulley. The ALTA pulley is not under driven and will not affect the life of your engine. The pulley is a lighter rendering of the stock crank pulley.
The reduction in weight is effectively the same power increase as removing 60 pounds of weight from your vehicle. The ALTA Performance™pulley will not wear out engine bearings or the oil pump, and will not add any additional vibration or noise.
Aftermarket under driven pulleys are prone to charging and drivability problems from being excessively underdriven. The ALTA Performance™ lightened crank pulley will have no effect on your cars charging system."
CLICK HERE FOR R53 CRANK PULLEYS
CLICK HERE FOR R56 CRANK PULLEY
rtk90
Aug 29, 2019 09:08 AM
The_Kid
Nov 3, 2016 06:30 PM
jesterofatlas
Sep 4, 2015 11:23 PM
M7Speed
Sep 3, 2015 07:48 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
