TPMS on 07' MCS
Old Jun 29, 2009 | 03:26 PM
tgs91
TPMS on 07' MCS
Been meaning to ask this for awhile now............
I went to non RF's recently and with the new wheels/tires I installed Discount Tire included a TPMS rebuild kit. The installer did not use them and when I asked about them he said the sensors are in the ABS system and not the valve stems.
I always thought that in the 07's and newer it was a valve stem based sensor.
Am I losing my mind?
Old Jun 29, 2009 | 03:41 PM
Minidrivr's Avatar
Minidrivr
Earlier 07s used ABS sensors. The change to valve stem sensors was around the August 07 builds.
Old Jun 29, 2009 | 03:43 PM
slinger688's Avatar
slinger688
I assume you bought a set of tires and rims (with TMPS sensors) already mounted and balanced. The installer just put them on the car. If you have TPMS, all you have to do is to reset it and it should work. Otherwise the tire pressure low light would be on.
Old Jun 29, 2009 | 03:55 PM
STLMINI's Avatar
STLMINI
What is the build date of your car? Also, it's not a convertible, right?
Old Jun 29, 2009 | 04:47 PM
Capt_bj's Avatar
Capt_bj
confirmed ...
my 07 has the ABS based system .... I took delivery off the lot in Oct and the "new" system was just beginning to show up...car was a new delivery to the dealer's lot. Many said I was past date and MUST have the new system but NO ... I do not.
Old Jun 29, 2009 | 05:11 PM
Minidrivr's Avatar
Minidrivr
Originally Posted by Capt_bj
confirmed ...
My August build 07 hatchback has the valve stem sensors. What's the build date on your car?
Old Jun 30, 2009 | 03:52 AM
tgs91
Mines a 1/07 build so it makes sense that this is ABS based.
Indicator has not gone off and not knowing the intracacies of the technology not sure what that meant
As always, thanks guys!
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
renchjeep
Sep 6, 2015 01:54 PM
