Lotus Elise rims on MINI
Old Jun 12, 2009 | 07:41 PM
Skeeter1's Avatar
Skeeter1
Has anyone tried to put rims from Lotus Elise on there Mini? Front rims are smaller than rear.
Old Jun 13, 2009 | 02:10 AM
xnotfunkylex's Avatar
xnotfunkylex
You'd have to make sure the bolt pattern would work. Not sure what it is, but adapters won't work for everything.
Edit: I should research first. I would go with 4 rear wheels, but now you have to make sure the offset will work.
Yes please.
Old Jun 13, 2009 | 04:17 AM
Skeeter1's Avatar
Skeeter1
Front rims are 5.5 x 16 and rear are 7.5 x 17. How would this change the performance. Mounting pattern is the same. How would I determine the offset?
Old Jun 13, 2009 | 06:28 AM
gnatster's Avatar
gnatster
Standard Wheel Specs
Front Rear
Dimensions 16" x 5.5" 17" x 7.5"
Bolt pattern 4 x 100 4 x 100
Weight 15.17 lbs (6.88kg) 20.94 lbs (9.50kg)
Offset +31 +18
Center bore 56.6 56.6
Old Jun 13, 2009 | 07:57 AM
Creeve's Avatar
Creeve
The fronts would fit the rears wont.
Old Jun 14, 2009 | 08:00 AM
quikmni's Avatar
quikmni
The size of the rears is good but there is not enough offset and they will rub on the outside.
Old Jun 15, 2009 | 01:02 AM
xnotfunkylex
The fronts are way to skinny. A 5.5 would just look wrong on a MINI.
If you ain't rubbin you ain't racin.
Old Jul 24, 2009 | 11:55 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Yo if you got the rims or have a friend with Elise give it a shot see if it fits, try Dremeling out the inner trim plastic. Also, check fitment of 17x7.5 on fronts too. I want to know to know cause if it "barely fits" I want to get the TR Motorsports F1 wheels in 17x7.5 all around
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
Accessory Products
Aug 10, 2015 01:35 PM
nomar116
Aug 9, 2015 09:42 AM
