Oil housing cap cracked
Old Jun 12, 2009 | 09:00 AM
sams05's Avatar
sams05
[SIZE=2]Hello,
My name is Sam. I recently purchased a 05 Mini with 30,000 miles and a auto transmission. I went to change the oil and noticed the cap to the oil housing was cracked (The cast nut). I managed to get the cap off and it does not look like it has much life left to it. Unforchanitly I had to put it back on because this is my ony transportation. My question is do they make a housing that I can bolt onto this motor that will accept a normal type of filter or will I need to get a new cap? Any help on this would be great. Anyone know where I can get these parts? Thanks, Sam
[/SIZE]
Old Jun 12, 2009 | 09:07 AM
Ken G.'s Avatar
Ken G.
When you say "oil housing" I assume you mean the can-type thing that contains the oil filter? If so, then I've not seen anything that would convert the engine to a spin-on filter. Besides, any sort of conversion kit would be a lot more expensive to buy and install than purchasing a new oil filter housing.
Old Jun 12, 2009 | 09:24 AM
surfblue's Avatar
surfblue
Too much torque I'd bet
Sam, your post is confusing. "cap to the oil housing was cracked (The cast nut)"...are you talking about the cap on the oil filter? IF so, it's plastic, and it takes a very low torque setting when tightening. Someone obviously over torqued it. You just have to buy a new one and replace the busted one, and you're all set. Check around on the forum for detailed oil change instructions, and stick with that very low torque setting.
Originally Posted by sams05
[SIZE=2]Hello,
[/SIZE]
Old Jun 12, 2009 | 09:32 AM
sams05's Avatar
sams05
Hi, thanks for your reply. That is the part but mine is definitely cast aluminum. Do you know where I can get one? Thanks again, Sam
Old Jun 12, 2009 | 09:33 AM
OWG's Avatar
OWG
Sam -
You are in the 2d Gen Forum, your '05 is a 1st Gen with a different engine.
Old Jun 12, 2009 | 06:16 PM
Edge's Avatar
Edge
AdMINIstrator
Thread moved to 1st Generation Stock Problems/Issues
Old Jun 12, 2009 | 06:55 PM
buzzsaw's Avatar
buzzsaw
$59.95 at http://new.minimania.com/web/Item/NME7635/InvDetail.cfm
Old Jun 12, 2009 | 07:52 PM
guidmini's Avatar
guidmini
caponmatic
Hey is right. This is 1st gen surf blue. Who moved who. Dumb. Sam what happened
is if you don't change a oil filter for a long time. The Canister Cap just freezes
up. Trust me. Cert Mini Tech here. I would have to use a big breaker bar
with the 36mm socket. I swear one time. I broke a 1/2 inch break bar.
Ok so you did get it off cool. You can go to dealer get that portion you need
just make sure dont cross thread when you install new cap.. Apply white lithium grease to new seal.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
