R56 Buying used Mini
Old Jun 5, 2009 | 04:27 PM
Yammy79's Avatar
Yammy79
Buying used Mini
Hello
I'm shopping around to get used Mini.
On the indicator, i noticed few minis had ! (exclamation) mark on it.
What does this mean? I don' have the manual so i can't check for the sign.
Does anyone know which site is better for VIN check ? Carproof or Carfax?
Could anyone check carfax for me?
Thank you ^^
Old Jun 6, 2009 | 06:32 AM
ronnie948's Avatar
ronnie948
Drive it for more then a mile
Don't just drive a used car around the block. Go for a real world drive. Check for any musty smells and if you can you should take it to a mini or BMW dealer for a check-up even if you have to pay a few dollars to have it done. I can't tell you what the ! is but it could be the computer needs to be reset or something. Push in the turn signal stalk and it should change to something else. A dealer will tell you on inspection before you buy the car.
Ronnie948
Old Jun 6, 2009 | 07:52 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
That indicator means that the Tire Pressure Monitoring System has detected that one of the tires may be running on a lower pressure then the rest. It could be that the owner had a tire go flat, had it fixed and they never reset the light. Or that a tire is slowly leaking. Or that a runflat is completely flat (kinda hard to see unless you are looking for it.)
Old Jun 6, 2009 | 10:04 AM
Btwyx's Avatar
Btwyx
If its just a big "!" in the tach, that just means the door's open with the key in the ignition.
The flat tire monitor has a cross section of a tire surrounding the "!". (Round sides and flat bottom.)
lalroma
20
Apr 2, 2022 06:19 PM
arf88
May 31, 2016 03:07 PM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
marendt428
Aug 8, 2015 04:44 AM
