Why doesn't my back-up light work?
Old May 26, 2009 | 02:10 PM
claancy's Avatar
claancy
I'm having trouble with the back-up light in the '02. It hasn't worked for a while, so I thought I'd change the bulb this weekend. Put in a new bulb.... no light. Tried the other bulb that came in the package.... no good either.
Checked the socket with my voltmeter...11.8V (engine off; battery voltage is 12.4). Disconnected the socket from the wiring harness, adjusted the tabs inside, put a bulb in it, and there's continuity across the pins, so the bulb has a good connection. Hook it up again, still no light.
Checked the voltage across the wires with the bulb installed, and I only see 0.5V.
Does this sound like the switch is bad (and unable to supply enough current to illuminate the bulb)? Or something else? Any ideas?
Old May 26, 2009 | 02:46 PM
ernesto's Avatar
ernesto
Coordinator :: Chicago MINI Motoring Club
I had the same problem, and this thread helped me to replace the switch myself. I think the part was around $20 or so.
Old May 26, 2009 | 03:05 PM
jvw's Avatar
jvw
I was thinking about the reverse light switch also, but if that is the case, why would there be voltage at the light socket? I don't think I measured the voltage when my switch died. I simply replaced it.
Old May 26, 2009 | 03:10 PM
claancy's Avatar
claancy
That's why I'm so puzzled by this.
Old May 26, 2009 | 04:19 PM
Minidrivr's Avatar
Minidrivr
Maybe the switch is on the ground side of the loop?
Old May 26, 2009 | 04:51 PM
claancy's Avatar
claancy
The voltage I measured earlier was between the two wires going to the lamp socket. I just went out and checked, and it has a switched positive & constant ground. The ground wire is good - I put the lamp between it and the battery and it lit right up.
Old May 26, 2009 | 07:07 PM
jvw's Avatar
jvw
I don't recall the exact configuration of the reverse lamp, but some other bulbs are in replaceable sockets. I've had trouble with some marker light sockets that get water in them and corrode. The lamp socket detaches easily from the wiring socket and is cheap. I've had to replace a few over the years. Just did one yesterday.
Old Jun 7, 2009 | 03:42 PM
claancy's Avatar
claancy
Well, I finally got around to installing the replacement switch, and that took care of it. The switch that came out was full of oil, like the one mentioned in the other thread. $13 for the switch from Classic, and 5 minutes to change it...not too bad.
Old Jun 24, 2009 | 07:46 PM
minXjaz's Avatar
minXjaz
Does anyone know where to buy the reverse light switch for the Mini Cooper S 2002 R53 online? Or is the dealership the only option? Anyone know the part number?
Old Jun 25, 2009 | 03:01 PM
claancy's Avatar
claancy
According to realoem.com, the part number is 23117527716. I bought mine from Classic MINI, my local dealer which happens to offer discounts to NAM members. I think it was around $13 with tax, because I picked it up at their parts counter, but they ship parts too. Their phone number is 440-585-9910. They have an email address too, but they don't always respond.
Getrieben
Sep 12, 2024 07:03 AM
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
stellaherself
Aug 14, 2015 05:28 AM
xraycat
Aug 12, 2015 02:36 PM
