BEST 16" TIRE VALUE UNDER $110?????
Old May 19, 2009 | 09:59 AM
n733lk's Avatar
n733lk
There are so many choices and opinions available, I thought I'd try narrowing the options by price. Looking for 205/55/16. Comfort, Handling, Treadwear.
Thoughts on Best Value for under $110 for daily driving???
Thanks!
Old May 19, 2009 | 10:32 AM
H&J's Avatar
H&J
Great question, especially today: I've had Yoko AVS 100 ($94 ea., great traction, low mileage: 17,000), Pirelli P6 ($104/ea.,poor dry traction, ok mileage: got 36,000 - 50k warranty), and TODAY at 2pm I'm getting BF Goodrich g-force Supersport A/S [205/50/16]. They are $111 ea. with a $70 rebate at America's Tire. Based on my research they are better traction than the Pirelli's with smooth ride and 30k warranty. Ditched my run-flats along time ago after I had a sidewall puncture.
Old May 19, 2009 | 11:32 AM
n733lk's Avatar
n733lk
Did you consider Yokohama S-Drives? Why did you go with BFG g-force? Have you always run 205/50/16?
Old May 19, 2009 | 11:55 AM
AutoXCooper.com's Avatar
AutoXCooper.com
My Tire Sponsor, www.fasttire.us gave me a set of Cooper Zeon's that I really like, http://www.coopertires.com/html/products/tires_uhp.aspx
My last two sets before them and after the OEM Dunlapped tires were http://www.thefuzionzone.com/hri.asp and I liked them very much too.
Old May 19, 2009 | 02:12 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Bridgestone Potenza R019's 195/55/16 HP All Season
You didn't mention whether or not summer tire or all season.
I have the Bridgestone Ultra High Performance All Season Tire above - I run them at 32 psi and rate them as follows on scale of 1-10, 10 being the best:
Appearance: 10
Tread wear: 10
Road Noise: 9 ( Some tires get real noisey after just 20,000 miles....)
Handling: 9
Ride Comfort: 10 ( handle road holes ect nicely too )
Wet Weather driving: 10
Light Snow: 9
Heavy Snow: 7 ? ( what the heck, what tire IS actually great in more than 6 inches of snow anyways, especially in a car that weighs only 2,500 lbs...)
Hope this helps. And remember, you get what you pay for
Old May 19, 2009 | 03:00 PM
n733lk's Avatar
n733lk
Gray Raven,
Checked out your Gallery; nice lookin' ride.
I live in Houston, but will likely look at all-season v. summer only. Our Winters can get a little chilly for a few days (). You know, with Global Warming and all.
Old May 19, 2009 | 03:12 PM
Btwyx's Avatar
Btwyx
Certainly if comfort is more important than handling, they're the most comfortable ones I've run so far. Handling is pretty good. Treadwear doesn't look like the best, but that's at the bottom of your list. Tire rack lists them at $85 each.
Any reason you're going for /55 not /50?
Old May 19, 2009 | 03:23 PM
n733lk's Avatar
n733lk
I'm concerned about the ride comfort. These run-craps have really put a bad taste in my mouth. I've never really paid attention to tire size prior to my Mini.
What are your thoughts on 50s v. 55s???
Old May 19, 2009 | 04:40 PM
H&J's Avatar
H&J
I wanted an all-season tire with great dry traction and a warranty. Mini's are famous for chewing up tires (I've been told it's the camber that does it, which also gives it snappier entrance into turns). I typically don't get even close to the warranty mileage. The Yoko's are probably like my AVS 100 were - great dry, summer traction, but lousy cold weather traction (I need the range from below freezing to 100 degrees) and the treadware was low.
Since I switched from run flats I have had 205/45/16 (Yoko AVS 100) which were great in turns because of the low profile sidewall, but it also made them much very bumpy on the highway (I could feel the proverbial paint lines on the road). Since then I have found I like the 205/50/16 best - softer ride with decent response.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Ntety
Sep 2, 2015 08:39 PM
