Navigation & Audio Speaker and amp compatibility. '07 HK into an '03 HK
Old Apr 16, 2009 | 03:02 PM
Penelope_the_MINI's Avatar
Penelope_the_MINI
Will a set of 6 H/K speakers from an '07 fit into my '03???
How bout the Amp?
Will it all still work?
- I'm pretty dumb when it comes to car audio so please speak in human words...
Thank you
Old Apr 16, 2009 | 03:32 PM
Penelope_the_MINI
bump
Old Apr 16, 2009 | 05:56 PM
GBMINI's Avatar
GBMINI
They're very different systems.
With loads and loads of work, it probably is possible to get it to work - but I wouldn't want to do it; certainly you'd plan a lot of car stripping wiring replacing, etc.
Old Apr 16, 2009 | 07:29 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You could probably do the speakers if you solder them. I don't see why the amp wouldn't be the same, unless soldering on a wire connected to an amp blows it up or something...
Old Apr 16, 2009 | 07:33 PM
ScottRiqui's Avatar
ScottRiqui
Unless the '07 you're talking about is a convertible, it likely doesn't have a Harman/Kardon stereo. I think MINI went with another manufacturer for the upgraded stereo (HIFI) in the second-generation cars (2007+ for the coupe, 2009+ for the convertible).
If the 2007 *is* a convertible, then the amp should transfer into your '03 with minimal problems (you might have to fabricate a mounting bracket), but only the front speakers will transfer easily (convertible rears are a different size than coupe rears).
But if the 2007 in question is a second-gen car, then as Edge says, it's possible, but it's going to be prohibitively difficult & expensive.
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
