R50/53 engine problem help
Old Mar 16, 2009 | 04:29 PM
addamaniac's Avatar
addamaniac
engine problem help
Error code: cylinder #1 misfire
warm compression test shows cylinder 1 at low pressure (30 psi) while other cylinders are all between 145 - 155. When the engine is cold compression shows no issues and cylinder #1 holds fine at 150psi.
when I pulled the spark plug, there was a small trace of oil on the plug.
whats most likely?
is there another diagnostic test that I can do that might shed more light?
thanks in advance
Old Mar 16, 2009 | 05:00 PM
Jhud's Avatar
Jhud
try a cylinder leakdown test. try the test both wet and dry. doesnt sound too good though
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
