Suspension Strut tower brace that works with stock camber adjustment?
Old Feb 27, 2009 | 10:14 AM
BlackSapphire's Avatar
BlackSapphire
I'm using the stock R56 camber adjustment slots (pushed inboard to their max) and I'm interested in adding a strut tower brace. I believe that most STB's are a fixed length that matches the factory strut location. Also, the center circle on the strut tower bracket itself won't easily accommodate sliding the top of the strut over due to interference.
Are there any strut tower braces that play well with the factory camber adjustment?
Old Feb 27, 2009 | 10:18 AM
IzzyG's Avatar
IzzyG
Only the JCW ones work with that adjustment.
Old Feb 27, 2009 | 10:31 AM
BlackSapphire
Thanks Izzy. I suspected that but I wasn't sure if I'd scoured all corners of the aftermarket earth yet Does the JCW clear aftermarket intakes?
Old Feb 27, 2009 | 12:42 PM
Smoogy's Avatar
Smoogy
I think the M7 brace might work. I only have the reinforcement plates right now, but they fit over the adjusted struts just fine.
Old Feb 27, 2009 | 03:08 PM
IzzyG's Avatar
IzzyG
The M7's don't work. As for the aftermarket intakes, JCW brace clears them IIRC.
Old Feb 27, 2009 | 04:16 PM
BlackSapphire
Thanks for the info guys... I'll probably just get some IE fixed camber plates and call it a day (although the STBs do 'look' cool!)
Old Feb 27, 2009 | 08:00 PM
krim's Avatar
krim
iirc, the NM one is adjustable.
Old Mar 2, 2009 | 09:09 AM
ghosthound's Avatar
ghosthound
going off of the pix, it doesnt appear to allow for the adjustment.
Old Mar 5, 2009 | 05:50 AM
krim's Avatar
krim
per JC
The bar is adjustable and you will be able to dial in some camber.
Old Mar 8, 2009 | 07:35 PM
berlinbill's Avatar
berlinbill
What strut brace would work best if I have the JCW kit? I saw that the JCW STB does not fit with it?
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
