Navigation & Audio which head unit will work with...
i know some of you guys have the knowledge.. im looking to find out if any head units will work with the steering controls???? Im wanting to put a flip out tv in the place of the stock cd player.. but im only wanting todo this if i can keep the luxury of this option that i paid for... im wanting to do "light" audio up grades to my cooper, nothing outrageous.. because i like the speed and handling.. thanks for your wisedom in this topic.....
This has been discussed before- do a search for MFSW
Jimmer0 wrote:
There is an adapter, by Blitzsafe, as long as you get either a BMW or Alpine deck, here's a thread
https://www.northamericanmotoring.co...amp;topic=3330
or any deck with an infrared remote you can use this
https://www.northamericanmotoring.co...amp;topic=1633
some info on a MFSW retrofit-Also read the MFSW pdf file enclosed.
https://www.northamericanmotoring.co...mp;topic=16206
I have ordered the Alpine CDA 7998R Fantom Face head unit, and want to know if the blitzsafe adapter you refer to will work with this deck and the multi function steering wheel. When i follow the thread below it seems to indicate that the blitzsafe only allows the OEM multi function steering wheel to work with an alpine CD Changer through the original head unit.
Will my Alpine CDA 7998R Fantom Face head unit work through the multi function steering wheel using the blitzsafe adapter?
:smile:
:smile:
I have the CDA-7998 (but I'm in the States so not the "R" version). I didn't use the Blitzsafe at all. I connected an Alpine CD changer to the CDA-7998 with the Alpine AI-NET cable that comes with the changer.
To enable the MFSW to work with the deck I used the SWI-X adapter from PAC.
Hope that helps.
Hope that helps.
Navigation & Audio help identifying a couple wires
yashmack
Aug 15, 2015 03:11 PM
