Suspension Lowering springs with stock-ish ride
Old Feb 22, 2009 | 02:03 PM
wkndracr's Avatar
wkndracr
I've decided to lower my car, and after searching quite a bit, I'm still not sure what to get. I had H-Sports on my old 03 MCS, and although I liked the ride, I wished the height was a little higher in the rear, so that the wheel gap was even f+r. I would figure my ideal drop would be 1"f and 3/4"r. (i'm rinning 215/45/17) It seems there are no springs made that give a little more drop in front. Which leads me to coilovers. The problem is that all coilover systems I see have a very high spring rate, which I don't really want. I suppose I can switch out the springs for something closer to the stock rates, but then I'm getting a bit over budget. I would be willing to spend about $1000 on a coilover setup, especially ones with a new front upper mount to combat mushrooming, but I'm at a loss as to which ones would give a stock-ish ride. How are the setups that utilize progressive rate springs? I'm interested in the H+R's but can't seem to find any good feedback concerning ride quality. Anyone have any suggestions?
Old Feb 22, 2009 | 02:12 PM
quikmni's Avatar
quikmni
I had H&Rs with stock shocks on my 2003 MCS. The ride was about the same as stock for normal driving. However, I thought that the front needed to be a little lower to balance the look. The actual height was good all around but the rear looked lower than a front due to the wheel well gap difference.
Old Feb 23, 2009 | 04:19 PM
Ryephile's Avatar
Ryephile
You want KW Variant 1 coilovers. Their spring rates are very similar to stock, and the assemblies are designed to lower the car 1.6" without sacrificing compression travel or overall stroke. This may be a lower ride height than you think you want, but it's a good place to be. I have KW V1 on my R56 and they're just as comfy as stock but improve steering feel by virtue of lowering the roll centers of the suspension.
Cheers,
Ryan
Sep 3, 2015 02:06 PM
Suspension Products
Sep 3, 2015 09:41 AM
old81
MINI5280
Sep 3, 2015 09:03 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
Sep 2, 2015 11:15 AM
