Cooper (non S) Modifications specific to the MINI Cooper (R50).
MINI Cooper 2002-2006 turbo question
Old Feb 16, 2009 | 11:17 AM
Speedchaser's Avatar
Speedchaser
hey i have a 2004 mini cooper (non s) and im going to put a turbo in it. i dont mind running 6 lbs of boost, but i would love to run about 12 or 15. this, as you can imagine, is way beyond the limits of the stock mini cooper engine. what i need to know is....
1. what parts of the engine does forced induction mess with (all parts plz)
2. and what parts am i going to need to upgrade.
Old Feb 16, 2009 | 12:42 PM
silversmoke06's Avatar
silversmoke06
contact jan at RMW
and usualy it needs a piston change to lower the compression ration.
far as i know the stock cranks are pretty tough.
however the stock head is like trying to breath thru a coffee stir
Old Feb 16, 2009 | 01:17 PM
IanF's Avatar
IanF
Search function be your friend... not a new subject...
Short version: Just about everything needs to be replaced and it's not worth the effort... there's a reason why few vendors have even bothered with turbo kits for the R50.
Jan will build you a turbo motor that will out-perform an S... but a) it's basically an turbo-only R53 motor, and b) your pockets had better be deeeeeep.
Of course, stating this rarely prevents a long, drawn out arguement from starting... right about... now...
Old Feb 16, 2009 | 06:34 PM
BoostyMINI's Avatar
BoostyMINI
Ooook So if you wanted to built an S for high boost what would you do? Take out the internals and put stronger parts in? Yes
And with a base cooper? The same thing.
So if you are going for high boost and not just moderate than use your original engine.
i wouldnt go over 6psi with R50 stock internals
Good luck, I am just now starting to peice together a low boost set up
Old Feb 18, 2009 | 07:49 AM
IanF's Avatar
IanF
The point is that the low/moderate boost set-ups have proven to be more trouble than they're worth - power gain : amount of work/expense... you basically end up with a car with less power than a stock S that's a PITA to tune (a confused ECU is never happy).
After much reading over the past... 5+ years... the best bang for the buck for increasing the HP of a Cooper is: cat-back, good intake, Jan-tune... do some suspension mods and enjoy the car for what it is.
But go for it anyway... not my car...
Old Feb 18, 2009 | 02:05 PM
wildcrazy442000's Avatar
wildcrazy442000
Just my opinion buy a used first gen "S". The crank, connecting rods, and pistons in a R50 just were not made to handle the extra stress of a turbo.
Old Feb 18, 2009 | 02:26 PM
ClubmanS's Avatar
ClubmanS
+1
The R53 MCS is a much better starting platform than the "Justa" R50. You already have all the beefed up components in the Supercharged model.
andrewjg1994
Jan 29, 2021 07:45 PM
jrezzo
Aug 9, 2015 10:32 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
