Does shutoff fan run in cold weather?
Old Feb 16, 2009 | 10:07 AM
gbsim's Avatar
gbsim
If my memory is right, my Clubman S turbo cooling fan ran after shut off even in colder weather at the beginning of the winter. I'm in Louisiana and the weather isn't really cold anyway.
A couple of weeks ago, I noticed that the fan wasn't running after shut off, instead I would occasionally hear a sound like something was trying to stop and start. Now I'm getting nothing.
Before the dealership tells me that "it's supposed to be that way", I thought I'd see if I should expect the fan to run on after driving say an hour or two in 70 degree weather?
Old Feb 17, 2009 | 07:25 AM
schatzy62's Avatar
schatzy62
The fan is on a temperature switch and will only run after shutoff if needed. Mine usually does not run after my 12 mile trip to work on the highway during weather colder than 22-23 degrees. BU t if it is warmer than that i does usually run.
If the car is only run for a couple of miles and did not warm up then the fan probably will not run.
Old Feb 18, 2009 | 06:21 PM
gbsim's Avatar
gbsim
But in weather of around 50 degrees you'd expect it to run after a 40 mile drive??
thanks.
Old Feb 18, 2009 | 08:01 PM
Benibiker's Avatar
Benibiker
It all depends on how hot your engine gets no matter what the temp outside is. Too many factors involved to say yes or no you have a problem. It's usually 80 degrees here in Hawaii and when I get home from work, sometimes the fan runs when I stop the car and sometimes it doesn't. It depends on how long I idled at a traffic light right before turning into my house. I think unless your car is overheating you have nothing to worry about.
Old Feb 19, 2009 | 05:21 AM
corcoranwtnet's Avatar
corcoranwtnet
Yeah, just check your temperature gauge...
Old Feb 20, 2009 | 11:31 AM
Lorne_K2's Avatar
Lorne_K2
Yes, expect it to run after virtually every drive, of any length and any temperature. At least, that's my experience.
I haven't driven it in sub-zero temps - but that is probably the only time it wouldn't operate after a drive!
That turbo sure gets hot...
Old Feb 24, 2009 | 05:10 AM
jimmiejo's Avatar
jimmiejo
It also has makes a difference if you run the compressor or not. The fan comes on automatically if your A/C compressor is running. This puts an extra load on the engine and it will get warmer - faster.
Old Feb 28, 2009 | 08:02 AM
zminitech's Avatar
zminitech
Check to see if your fan fuse is blown, it's either a 30A or 40A fuse in the engine bay on the driver's side. If it's blown, it's probably a 30A and needs to be replaced per campaign, with a 40A fuse.
TREX
Nov 2, 2019 07:31 PM
minicoclub
Nov 11, 2015 07:25 AM
minicoclub
Aug 25, 2015 09:07 AM
Powershift
Aug 16, 2015 05:14 PM
