R50 Keyless Entry Stopped Working
Old Feb 15, 2009 | 12:21 PM
hackish's Avatar
hackish
I had my employee replace the bottom steering wheel assembly because the u-joint in it was getting sloppy. I also replaced the shifter and cables. Now I've noticed that the keyless entry system and power locks do not work.
I checked the F37 fuse and it's fine. I checked BC1 and it's nice and dry. I suspect the keyless entry module may have gotten unplugged but I have no idea where it was located. We did a lot of work on the car and it's tough to narrow down when the keyless stopped working.
Can anyone tell me where I'd find the module? Here is a diagram of it.
http://www.realoem.com/bmw/showparts...38&hg=61&fg=25
Old Feb 22, 2012 | 11:41 AM
Shiftyone's Avatar
Shiftyone
I have a keyless entry issue as well, and even though I have not fixed mine yet, I believe the keyless entry module is behind the clock, "from below it looking up." You can remove the clock by popping out housing from the front "nearest the display," and then pulling it towards you. I was hoping my module was simply unplugged, but it isnt.
Old Feb 23, 2012 | 07:06 PM
Kooperscooper's Avatar
Kooperscooper
My power door locks work with the key except for the driver side door. If I put the key in I can lock or unlock all the doors. Could I have something wrong with the driver side door?
danielbrookes_9
Oct 3, 2015 12:51 PM
Emnotek
Aug 13, 2015 05:47 PM
Eric Chen
Aug 12, 2015 12:04 PM
ludedude
Aug 10, 2015 07:16 PM
