R56 Fluids in my MINI?
Fluids in my MINI?
I just got over with my break in period and i want to put fresh fluids in my mini. i checked my owners manual and it doesn't tell me @#$% about the type of transmission fluid or how much, it also does not say how much oil to put in when you change the oil with a new filter and all? and after i drain my transmission fluid where would i fill it back up on the mini?
I would think you do not need to change the transmission fluid after the break-in period (assuming 1200-2000 mi), auto or manual.
For the motor oil, 5w30 Castrol Syntec is recommended about 4.5 QT approx with new filter. Fill in 4 Qt first then check the dip stick to see how mch more you need. I use 0W30 Castrol in the winter and 5W40 (or 0W40) Redline in the summer.
Automatic or manual? If manual, I asked the tech guy for the BMW CCA, and he recommends Red Line MTL changed at 1200 miles, then every 30,000 thereafter.
I generally change my manual transmission on my cars quite often, every 2 years or so. I am still not sure if you need to do it after break in. I do it more often if I track the car a lot.
As for the Automatic; drain is all too easy and refill is a huge job.
[Single post link here about one Auto Transmission refill.]
Open that whole thread for one of the best DIY discussions on Oil/Filter changes.
The Automatic Fluid is supposed to be "Lifetime" or 100k miles, WOF.
The ATF has to be a special BMW Fluid, very expensive juice.
There is no dipstick or other way to check level, or feel/smell the fluid.
09R56
11-16-2022 10:49 AM
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
bleonard1401
08-11-2015 02:53 PM
