R50/53 Lower Control Arm Ball Joint question
Old Jan 22, 2009 | 09:56 AM
JAB 67's Avatar
JAB 67
In an R53, is it possible to remove the ball joint at the apex of the front lower control arm without dropping the subframe?
Old Jan 22, 2009 | 11:14 AM
k-huevo's Avatar
k-huevo
Yes, pry/pull drive axle from transmission, unbolt ball joint bracket, use universal ball joint seperator (KD 3916).
Old Jan 22, 2009 | 11:21 AM
JAB 67's Avatar
JAB 67
Thanks.
Old Jan 23, 2009 | 05:03 AM
03BRG's Avatar
03BRG
https://www.northamericanmotoring.co...nsmission.html
This shows pics at the end of the thread of the control arm removed without subframe being pulled. Might help
Old Jan 23, 2009 | 10:49 AM
k-huevo's Avatar
k-huevo
If you look closely in those photos you will see all the subframe bolts have been removed and a jack is underneath to lower the subframe, to get the bushing brackets out, the subframe had to be lowered even if not dropped to the ground.
To remove the inner ball joint bracket either the driveshaft has to be removed or the subframe lowered; the driveshaft tripod bearing & boot are in the way of removing one of the ball joint bracket bolts.
maestro39
Oct 27, 2015 02:38 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
OutMotoring
Aug 6, 2015 09:32 AM
