Reassembled Engine - Zero Compression. valve Issue?
Old Nov 26, 2008 | 04:27 PM
Chibi Archillies's Avatar
Chibi Archillies
So the saga, continues...
...had my engine reassembled at a repair shop. they swear the timing is correct. they did NOT do a valve job nor replace the rings. the top end worked when i dropped it off.
so right now, across the board, i'm gettign ZERO compression (used gauge).
the shop suggested that the hydro-rockers needed to be bled.
i took them out and compressed each one until there was no more oil coming out of the little bleeder hole. put them back in.
same result.
it sounds like im starting the engine with no plugs in it. it spins up fine, but no kick....
there is spark coming to each plug wire, there is fuel on each one, the fluids are full, and vacuum hoses are all connected.
suggestions?
Old Nov 26, 2008 | 05:31 PM
norm03s's Avatar
norm03s
Hydraulic lifters need to be pumped while submerged in oil. You have collapsed the lifter by pumping all the oil out of it. Who tighten down the valve train in firing order?
Old Nov 26, 2008 | 06:44 PM
Chibi Archillies
not sure what you're asking about firing order? i put the lifters back on the motor
so youre sayign i submerged the lifter in motor oil and compress it all the way down the way ive been doing it? than it will stay all the way down or at least be in neutral position?
EDIT:
if there is an order what is it?
also, describe if you can the proper way to "clear" the lifters so they dont overextend on the valves and stick them open once i return them to the head.
Old Nov 26, 2008 | 08:39 PM
Chibi Archillies
tried to submerge them in oil. pushed the open one, up and down, nothign happeend. the other one stayed down where i put it.
heres a pic for visual help.
again, the shop suggested i have all the lifters in the down position, as they are supposed to fill with oil once the car is started and runnign for abotu 15-20 seconds...
...so i need to figure out how to return them to that state. the ones i actually got down, were easy. bled them out with a small C-clamp. the otehr bled out as well, but an internal spring i guess keeps them in the up position....
suggestions???? need this done ASAP>
Old Nov 27, 2008 | 10:55 AM
03BRG's Avatar
03BRG
The only way it could be lifters causing the problem would be if they were stuck all of the way out and not let the valves to close... Watch the valves as you turn the motor over by hand does the valves open and close right? Try a compression test with the rockers off so all of the valves are closed. Remove the spark plugs and compression test. This way you rule out alot of unknowns and timing does not matter at this point. IF it passes then valve train is the problem. Test fails- bad tester? bad pistons? good luck!
Old Nov 27, 2008 | 01:54 PM
kapps's Avatar
kapps
What about a leakdown test with the rockers off? That should tell you if anything is leaking past the valves or rings. If it passes that, then it's definitely the valvetrain.
Old Nov 27, 2008 | 02:32 PM
not-so-rednwhitecooper
I would do this.
The car should still start and build some compression even with collapsed lifters.
Old Nov 27, 2008 | 03:06 PM
Chibi Archillies
will try compression test with no rockers.
but im tellign you the shop swears up and down i need to zero the hydrolic lifters. they are extended out and need to not be.
so how do i return the ones with no oil in them that are stuck out back to zero???
Old Nov 27, 2008 | 03:32 PM
JAB 67's Avatar
JAB 67
I don't understand why the repair shop that 'reassembled' your engine isn't the one worrying about this. Have they ever rebuilt a MINI engine before? Sounds like not, to me.
Old Nov 27, 2008 | 03:58 PM
Chibi Archillies
no.
did a compression check with no rockers. put a bit of oil in cyl's.
about 120 give or take....
and the shop only reassembled my engine. i took it to them after i had to get a new crank and rod and bearings...
Old Nov 27, 2008 | 04:05 PM
Chibi Archillies
checked timing.
the arrow on cam is at about 1 oclock and the two copper links are at about 3oclock
EDIT:
shoudl these points line up?
Old Nov 27, 2008 | 05:44 PM
03BRG's Avatar
03BRG
Because the motor has been turned the links do not matter now unless you can see the crank timing marks and redo the chain PITA. I would at this point bolt down the rockers drop a coat hanger type wire into the #1 spark plug hole with all of the other plugs removed by hand "turn the motor the same direction as if it was running". What you will/ should see will be as the intake valves open the piston should be going down per the wire that is riding on top of the piston as the piston comes back up the intake valves should then shut and the wire with just alittle more turn should be TDC. If things differ from this alot I would say its out of time. The lifters should compress as you bolt down the shaft this should not be the problem if anything like someone stated they should just be to loose.
Old Nov 27, 2008 | 09:06 PM
Chibi Archillies
well.
somethign i didi must have worked, as the car starts and ive driven it baby steps to see if anythign leaks, or rattles, etc.
everythign seems to be running fine.
the check engine light is on solid, so ill ahve to find someone with a reader and see what code its spitting out.
thanks for the advise guys/gals. hopefully the next time i have to do this its on someone else's car. but at least i knwo now how to take a motor out and put it back.
:D
Old Nov 28, 2008 | 04:51 AM
03BRG's Avatar
03BRG
Good to hear all is well!
09R56
Nov 16, 2022 10:49 AM
bobbiemartin
Jan 20, 2016 05:28 PM
David.R53
Sep 1, 2015 06:49 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
