Suspension Coil-over help
Old Nov 4, 2008 | 03:24 PM
MINI_chili's Avatar
MINI_chili
Coil-over help
I ordered a set of coil-overs (cross), but they did not come with installation instructions. It seems pretty straight forward and there is a how-to here on NAM, but the part I'm worried about is the torque specifications. I remember a while back coming across a link to a site that has the stock parts and their torque specs (for the most part), but I can't find it again.
Does anyone have those specs handy?
any help would be greatly appreciated-I'm hoping to put these on before the weekend
thanks
-Nick
Old Nov 4, 2008 | 05:33 PM
k-huevo's Avatar
k-huevo
Torque values for R50-R53 suspension
End Links 56Nm/41ft-lb
Rear Strut top nut 30/22ft-lb
Rear Strut Support to Body 56Nm/41ft-lb
Rear Lower Strut Bolt 140Nm/103ft-lb
Front lower strut pinch bolt 81Nm/60ft-lb
Front strut top nut 64NM/47ft-lb
Front guide support nuts 34Nm/25ft-lb
The rear Cross strut shaft top nut may require a different torque value if the shaft’s bolt end is larger than stock.
Old Nov 4, 2008 | 06:52 PM
MINI_chili's Avatar
MINI_chili
thanks, this is great
Old Nov 6, 2008 | 03:01 PM
MINI_chili's Avatar
MINI_chili
IN the middle of install
need a bit more help. I'm installing the rears right now and there is no top plate provided my my system. I figured I was supposed to take the one off the stock set. and, confirming my worries, it popped apart when removing the top nut. I don't want to take the top nut off the new set b/c I want to make sure this is what I'm doing. Maybe I'm just doing it wrong
any help appreciated
thanks
Old Nov 6, 2008 | 03:05 PM
MINI_chili's Avatar
MINI_chili
Here's a pic:
I was also wondering about the end links... they reverse, and I'm having trouble getting those in too
Old Nov 6, 2008 | 08:09 PM
MINI_chili's Avatar
MINI_chili
never mind, I figured it out. those end links were for the front and the springs weren't an issue
SpeedRacer0212
Suspension
Aug 22, 2012 09:08 PM
txwerks
Suspension
92
Dec 29, 2009 01:56 PM
paco3
May 24, 2008 08:57 AM
