Suspension Torque Specs?
Old Nov 2, 2008 | 08:23 AM
Herman da German's Avatar
Herman da German
Torque Specs?
I installled H&R coilovers, Alta 19m sway bar, Alta sway bar end links, Alta lower control arms. Does anyone know what the torque specs are on all those bolts?
Old Nov 2, 2008 | 09:00 AM
k-huevo's Avatar
k-huevo
Axle Carrier to Body 100 Nm/74ft-lb
Stabilizer Bar Bracket 19Nm/14ft-lb
End Links 56Nm/41ft-lb
Control Arm 100Nm/74ft-lb
Strut Top Nut 30/22ft-lb
Strut Support to Body 56Nm/41ft-lb
Lower Strut Bolt 165Nm/121ft-lb
The only torque value different from the R50 - R53 on the rear suspension is the lower strut bolt 121 ft-lb (R56), 103 ft-lb (R53)
Old Nov 2, 2008 | 02:40 PM
mattbren
Is the lower strut bolt torque the same front and rear?
Old Nov 2, 2008 | 04:13 PM
Herman da German
Thanks for the info. I would be lost if it wasn't for this board.
Old Nov 2, 2008 | 10:22 PM
k-huevo's Avatar
k-huevo
81Nm/60ft-lb for the front.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Fordgt4
Oct 10, 2015 10:42 AM
MGBill1186
Oct 2, 2015 06:54 AM
gnhovis
Sep 28, 2015 10:56 AM
