Yoko AVS ES 100 Users.... Whats your P.S.I?
Old Sep 18, 2003 | 09:55 AM
skrutzen's Avatar
skrutzen
Just got my Yoko's put on yesterday and was wondering what everyone seems to find as the best psi for the tires. right now they're at 30 which was what my tire guy inflated them too. TIA
Old Sep 18, 2003 | 10:10 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
It will vary depending on your MINI- MC vs MCS and your load 2 vs 4 people.
Each car has a door jam side label (driver's side) that has the range based on the size of the rim and the size of the tire. Yoko ES 100 comes in a variety of sizes and so you look for the closest match to what you have and read the numbers off the table.
For me my rims are 17x7 and tires are 215/45-17 so with two people most of the time I run about 33 psi cold front and back. If I want load of 4 people I might increase psi to about 37 front and back. If I take my car to the track I might change the psi to 32 in front and 38 in back and adjust that day up and down for track conditions in an attempt to control understeer and be as neutral in handling as possible. Best readings for tire temps at the track from a tire temp monitor on the tire sides and mid tread.
Old Sep 18, 2003 | 10:27 AM
Bluegarvis's Avatar
Bluegarvis
I run 32 all around for everyday. At autocross, I run 38 rear, 35 front on my stock suspension (this helps the rear rotate a bit easier). On track, I currently run 35-36 evenly...
stock 16" v-spoke rims, btw
Old Sep 18, 2003 | 10:35 AM
red03miniS's Avatar
red03miniS
32psi front and back cold
usually 2 people..sometimes three
17 inch rims
Old Sep 18, 2003 | 11:09 AM
skrutzen's Avatar
skrutzen
Thanks everyone, I should've mentioned that I have a MCS with stock tire sizes. Also, nine times out of ten I'm by myself in my car but at most one other person. Thanks again!
Old Sep 18, 2003 | 11:11 AM
goin440's Avatar
goin440
I got 205/45/17 avs es 100s on my MC; 32 front, 31 rear.
_________________
-goin440 IB/IB MC on 17" Volks
Old Sep 18, 2003 | 07:57 PM
MGear's Avatar
MGear
I prefer the ride and handling of my Yoko's at 33psi front and back.
ian260
Mar 29, 2017 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
gnhovis
Sep 28, 2015 04:07 AM
