Helix Camber Plates Special
Old Oct 31, 2008 | 02:05 PM
Ralph@Helix's Avatar
Ralph@Helix
Hey Folks starting Today through next Friday 11/7/08 our Camber Plates will be on sale for $404 (normally $449)!!
You can order these by giving us a call at the shop 215-739-8800 or online. For online orders in the Additional Comments section please enter "nam promo" to get this special discount.
Helix camber plates for the 2002-2006 Mini Cooper & Mini Cooper S
We feel these are the best camber plates in the industry. They install using the stock mounting holes and do not require any drilling or fender butchering. They mount below the fender allowing for after-market strut braces. The main plate has a machined retainer groove to maintain factory caster settings. Very easy camber adjustment from the topside using two aircraft-grade bolts. Complete bearing holder system retained from above, avoiding the poly bearing pull-through so common on other designs. These bearings assure quiet street operation in marked contrast to harsh monoball designs. The Helix camber plates work with stock or aftermarket struts and springs or coil-overs, including adjustable Koni struts, Bilstein PSS9, and H&R Coilovers. Constructed of steel and aircraft-grade aluminum, all parts are either hard anodized or cad plated.
Reviews:
“I have just had my Helix plates installed with TSW Adj. endlinks and Koni Coilovers and Helix Rear lower control arms. I took the car to a private Porsche shop http://doughertyautomotive.com/
They said the Helix camber plates where one of the best made that they have seen in a while. Everything was easy to install and adjust to set the car up and align perfectly.”
“i have the helix camber plates. these things are massive and well engineered. i have camber adjustability and don't have to worry about 'shrooming. one product solves two issues.”
for my install and alignment and they loved the set up.
*Let us know what other Helix Products you want a special on! Vote in our thread here
Cheers
215-739-8800
conky
Apr 6, 2016 08:03 PM
ej
Nov 17, 2015 09:21 PM
dropnstylez
Oct 29, 2015 08:57 AM
vargasgal
Sep 17, 2015 10:02 AM
Ryan Caballo
Sep 10, 2015 10:10 AM
