Happy Halloween! - Car Covers, Improve MPG, Gift Ideas...
Old Oct 30, 2008 | 07:35 AM
Mini Mania's Avatar
Autumn leaves are falling, is your Mini covered?
Natural Hazards To Your Mini Cooper Paint:
Did you know that even non-industrial chemical sources can be hazardous to your paint? Splattered bugs, bird droppings, and dead autumn leaves all have the ingredients for a destructive chemical mess. When wet leaves sit on your cars finish for a few days, chemicals can etch down into the paint. In some parts of the country this can be so common that it happens even on new car lots. If the leaves are not cleaned almost every day, the paint can be so severely damaged that only a complete re-paint can make it look good again. Bird dropping can be an even worse problem. The problem is worst on the flat surfaces of the bonnet and top. After they dry up they then are baked into the paint with the sun. And in some areas of the country, even the water from a Sprinkler will leaves stains on your paint! Protect your car- put a car cover on it!
Water Resistant
Car Cover
$159.95
Technalon
Car Cover
$189.95
Techalon
Wagon Cover
$189.95
Car Cover
Cable & Lock
$11.95
View even more car covers!
Improve your MPG AND your performance at the same time!
45D (A+ Series)
Distributor
$179.00
45D (A Series)
Distributor
$179.00
Elec Ignition
Conversion Kit
$119.95
Performance
Wire Set
$59.95
Identifying your Mini is now even easier!
The Holidays are coming! Here are some great gift ideas!
1:18 Scale
Classic Mini
$32.95
Mini Cooper
Parking Sign
$22.95
Classic Mini
Mouse Pad
$26.95
Gift
Certificates
From $10.00
Have you changed your oil lately?
Oil Filter
& Spark Plug Set
$17.95
Spin On
Conversion Kit
$89.95
Spin On
Oil Filter
$10.95
MiniMag Magnetic
Oil Filtrations
$74.95
View all oil filters!
Minis For Sale:1983 Austin Mini Panel Van Wagon - PA ($14,000)
"Fully restored Mustard Yellow classic mini panel van. Sandblasted bodyshell, jig mounted all panels welded with OE rover panels. Painted, inside , outside , underneath. Engine and gearbox rebuild, all new brakes, new wiring. More pictures available on request. "
View This Listing || View All Listings
Old Nov 1, 2008 | 04:40 AM
gasmini03's Avatar
gasmini03
Do you actually have an Austin mini pickup that you make the car cover to fit or do you go off of dimensions that you can find on line of the pickup? I am talking about Part No: C5208GK in your online catalog.
Old Nov 2, 2008 | 06:49 PM
Mini Mania's Avatar
Yes, out pick-up car cover has been made for many years to fit an actual Mini Pick-up. PS- I have owned one for 20 + years!
dpcompt
Aug 12, 2015 07:39 PM
ludedude
Aug 10, 2015 07:16 PM
Dashdog
Aug 10, 2015 06:17 AM
bctf1
Aug 6, 2015 12:55 PM
