Right hand axle support bearing
Old Oct 16, 2008 | 12:27 PM
orvillespooner's Avatar
orvillespooner
Has anyone replaced the carrier bearing that supports the two piece RH axle? The whole thing rebuilt is over $500.00 US. I am in the process of pressing it off, and need to buy a new bearing.
Old Oct 31, 2009 | 06:53 PM
myla2003's Avatar
myla2003
I'm doing a transmission swap (R50 to R53) and bought a new RH axle, but it didn't come with the carrier bearing. It doesn't seem like the one on the R50 axle will fit with the R53 setup. I've put it on, but it simply doesn't fit. Did you ever find a new bearing, and if so where?
Old Nov 1, 2009 | 06:56 PM
Densmini's Avatar
Densmini
I'm pretty sure the R53 bearing has a larger diameter inner race.
Old Nov 2, 2009 | 07:47 AM
myla2003's Avatar
myla2003
Nope. The R50 bearing fits perfect on both axles. The problem is that with the Getrag Transmission, the axle sits about an inch and a quarter futher back from the engine at the point of the support bearing than it would with the Midlands. In other words, if you put the R50 support bearing on the R53 axle and try to mount it to the engine, the will be a gap. The Getrag transmission is larger than the Midlands.
Old Nov 9, 2009 | 12:45 PM
pmfranke's Avatar
pmfranke
new axels
I bought a new axel with bearing for $120. from AUTO PARTS PLACE.com no more clicking and new boots !its all good. why pay 50 bucs each for boots when you can have it all new ?
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
Supertractor3
Apr 7, 2017 11:16 AM
QuickCooper
Dec 29, 2016 06:46 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
