R50/53 Glass scratch
Glass scratch
Like my MINI, one of my other cars has a rear wiper, and the previous owner was slow to replace the blade insert, and as a result the arm left a semi-circular arc on the glass. Any suggestions on how to remove it?
buff it out with a sander
just kidding dont do that... ive never seen anyone remove or repair scratches in glass.
edit: google search found these,
http://www.essortment.com/hobbies/di...repai_sggt.htm
http://www.gtglass.com/
looks like kind of a port/polish technique
just kidding dont do that... ive never seen anyone remove or repair scratches in glass.edit: google search found these,
Try this kit
This kit should work well with what you described.....but if its deep enough to get your fingernail caught it, it may be too deep for this kit to work......
http://www.autogeek.net/glass-repair-kit.html
I have seen some of these kits and if the scratch is light you can improve it but the only real solution for deep scratches is replacement.
However, if it is light using a polish kit could help.
Good luck and let us know your results if you use a kit.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
