R50/53 Grill size difference between R50 & R53?
Old Sep 24, 2008 | 01:07 PM
BEAVR's Avatar
BEAVR
Is there a top grill size difference between the mini and miniS?
found a front grill which I may want to swap mine out with, but its an S model.
Old Sep 24, 2008 | 04:16 PM
rkw's Avatar
rkw
Top front grills are the same size between R50/R53, fully interchangeable.
Old Sep 25, 2008 | 04:37 AM
bond007's Avatar
bond007
Yep, they're fully interchangeable, BUT if the grill you're looking to swap is from an '05-'06, the outer trim will be different, as in the '02-'04's that trim is "ribbed", on '05-up it is smooth.
Old Sep 25, 2008 | 09:56 AM
BEAVR's Avatar
BEAVR
thanks, the outer trim looks ribbed so it should fit perfectly.
wkp1219
Nov 13, 2015 07:52 AM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:59 PM
Aug 11, 2015 12:58 PM
